This is the best advice so far (not to discount our other knowlegdeable sources!).Q451990 wrote:In San Diego, it might be worth having Jerry Tucker (or his shop) take a look at it. http://www.jerrytucker.net
Heath
Yeah I know their actually run in a much smarter manner than what they use now. The main reason I suspect the sunroof seal is that there is a large section of the rear that is missing. I have temporarily filled the gap with butyl gum until I actually order the part. I keep spacing on getting it.NJ 666 wrote:I've seen that on J's before but more often it is the plastic windshield support seal that leaks water into the HVAC box onto the ECM. The sunroof drains go all the way into the rocker panel so it's USUALLY not the drains.
Blame whoever posted this. Since we're here what was the final verdict?Q45tech wrote:Bad bad posters [hit dog with newspaper] How did a question about a 99 Q41 digress to a Q45 then to a J30. It's a wonder someone didn't chime in with a G20 or 35 or me with an AMG.
Never seen an ecu fail and hold injector open on a 90-95 Q..........they [driver transistors] are designed to fail open.........................the converse is usually the rarity..........loss of drive to injector.Don't confuse experience with peak hold injectors to saturated type used on Q.
Members must be careful about following advice of posters with less than 10,000 posts and low experience [those that don't work on multiple Q every day].They will often rehash what the read not fully understanding the details.Reader Beware Is The Mantra Here.
don't work well.
The search function works relatively well when you use the topic body feature, and many cases are worthy of a new thread, or the information can be found on articles sections.Q45tech wrote:Bad bad posters [hit dog with newspaper] How did a question about a 99 Q41 digress to a Q45 then to a J30. It's a wonder someone didn't chime in with a G20 or 35 or me with an AMG.
Ever wonder why search functions don't work well.
Yes. Just start it, let it run for a good while. You need to start and run the vehicle at least ONCE every 2 weeks. Oil needs to circulate and gravity just pulls on it.sandor wrote:It sounds like it could be a noisy HLA to me. If that is the problem, it will go away after the engine idles some and it pumps back up. Using some MMO during your next oil change should help. Please keep us informed of what you find.
Good luck!
The rough idle could be caused by lots of things...Open injector (Although you would have drivability problems at all times.) Dirty plenum, or MAF connectors, etc. It's possible the idle problem and noise are not related. There are many here more experienced than me to weigh in on this.NJ 666 wrote:How can a noisy/loose/worn HLA cause a rough idle?
Thank You, Steve the Tech. I may be a rookie or one of the best techs in the nation. Posting has to start somewhere. Most people here give suggestions or a direction to go in for a accurate diagnosis. Sorry if I spoke out of turn.
squadone619, what was the outcome? See I'm trying to learn.
