PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Sat Nov 22, 2014 7:55 am
So you are swapping just the 97 block and head into the truck, but still utilizing the 93 intake manifold?
I can't see an issue with that. All the injectors do is inject the fuel into the intake runners... as long as the runners eventually get to the head, you'll be fine.
Nissan might have changed the design to get the fuel to be injected into an area of more air turbulence or something, to aid with atomization/combustion/emissions/fuel economy, but the old manifold should still work.
