Im having almost the same problem. My RPMs dip to about 700-800 when I clutch in to slow down or downshift.edmond wrote:One thing I didn't mention before. If I remove the pedal and let it slow down by itself, the engine won't stall. However, if I press the clutch to shift to N, the times when I press the clutch, the rpm will drop very quick and then the engine stall. So it can actually happen also when the car is running and the clutch is pressed long enough to let the rpm drop till it stall. But it usually doesn't happen b/c the times to shift the gear is shorter then the times it drops the rpm to zero.
You know, I just realized the main reason I feel it like I do is because of my urethane mounts. What it does is drop to 700-800, then bounces off of it and raises back up.vancouverbc wrote:they dip to 700-800 rpm? what is wrong with that?
Oh wow, thanks a lot for the info man.vancouverbc wrote:yes. see iacv in tutorial link in my signature
