Engine rebuild, Wiseco's ACL bearings, blah blah. need a couple opinions.
zero_gripS13
Car: soon to be 95 s14 hopefully
yea acl race series.
im gona measure the clearances to make sure but should be an issue.
oem bearings are a bit expensive would of cost me like 60$ more than acls.
KEMP
Car: 1990 240sx CA18DET
ya, on my motor, i didnt want stock bearings, its stupid to do that when you plan to rev almost 9k, and when its a semi built motor.
also got a spec stg3 6puck clutch and new oil cooler with lines.
bentvalves
Car: 89 Silvia K's
its not a stupid idea to use OEM bearings in a "built" motor, not at all.
all the different numbers stamped on the crank basically mean all the main/rod journals are slightly different sizes.
using all the different grades supplied by nissan ensures perfect clearances every journal, nissan didnt do that to look cool either.
Modified by ks13 at 9:02 PM 2/19/2009
