Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Sun Jan 30, 2005 12:03 am
These guys are right in that an MAF can cause this problem, if any of you have a FSM you will note that the Nissan ECU has a provision in it for a safe mode. However, there are 2 others that will set this sort of fault. First is throttle position sensor, second is Knock sensor. You will be able to find out by running codes on your ECU. I had this happen, and my car spent 6 mos down, mine, as you will find most peoples are, was MAF. But these are others that will run in the safe mode. I will take a stab at the system, you can barely get the engine to move above 2K, except for fluttering the pedal. When you do, and get it up to 2.5K, it will want to act like it is flooding out, until it falls back down in RPM, then you get to do it all again.
