Engine oil
Florida240sx
What would be the top oils to use in a KA-T??Seen some things like royal purple, or add lucas to your normal, and synthetic....What is some of the best? bought a case of redline gear oil...do they car motor oil also?
kapower06
Amsoil and Mobil 1 are said to be the best synthetics made. Some think mobil 1 < amsoil some think mobil 1 > amsoil. With either oil you cant go wrong. Please stay away from additives. The top name oil companies go through alot of R&D to make the additive packages in their oils, so dont mess with them by using additvies... If you can afford it Motul makes a very good oil but its very expensive anywhere from $8-$25 a quart. Its very important to use a good quality oil filter to, not a POS fram one.
fiznat
Car: Grown up :(
Are you talking about motor oil or gear oil?
Also, what kinda engine are you running? Freshly rebuilt or an older engine that was turbocharged late in its life?
KATwo40
Car: 1993 240sx KA-T
I use Aunt Jamima. Nice and thick.
J/K.
Like posted above, stay away from FRAM filters. I've been using a WIX filter for a while and I've been pretty happy with it.
jmwenick
Car: 1991 240sx Base Model
Whats soo wrong with Fram filters? I use the Heavy duty fram filter and Mobil 1 Synthetic in my 92 celica, and have put 85,000 miles on it with zero problems. The car has 198,000 miles and still runs great. It is a Toyota tho.
KATwo40
FRAM filters are notorious for dropping pressure at low rpm. While there's not much requirement for decent oil pressure at idle, I still like to see at least 18psi. Lots of cars see more like 8-10psi at idle.
WDRacing
80% of all the filters made are built by fram...
I've used Fram for 10 years on high hp cars. I swap a new filter in between changes as well, Doubling my filtration. To cheap not to do.
WDRacing
Turbo motors like thicker oil, I use 15W-50 Mobil 1 or Castol Syntec.
KATwo40
15/50? I would have thought that to be too thick.
However, you've much more exp with the KA than I and I make like...220whp? hehe.
Jookmasta
i also use 15w50 mobil 1 synthetic and have been using fram filters since day one. and after about 12 years and 152K, no issues with either the oil or the filter. the oil does get dirtier alot quicker since i went ka-t though. cant win em all right? lol
GEO
Car: 95 240sx KA-T
I use 10-30w pennsoil non-synthetic ...
TheOne
Car: 93 240sx FB
http://minimopar.knizefamily.n....html
^^talks about a lot of oil filters and who is the actual maker.
Edub1
Car: 89 240sx KA-T
Damn, for that picture you've got there I'd have to say K-Y.
nissanfanatic
Car: 1992 Nissan 240sx SE
I use 10w-30 Mobil 1 synthetic and a Mobil 1 synthetic fiber oil filter. It has treated me and my engine very well over the years.
Craving4Boost
Car: 91 240sx fastback
GEO wrote:I use 10-30w pennsoil non-synthetic ...
why??
nismofly
Car: 89 Nissan 240SX Hatch
right now, napa gold filter with valvoline dura blend, 5w-40 iirc, ill be getting more careful though in the 2-3 changes leading up to the turbo install
GEO
Car: 95 240sx KA-T
Craving4Boost wrote:
why??
Why not? I always was told that if they didn't use it from the begining, then it would casue problems if used now. Someone clarify this?
nismofly
i think hes referring to the pennzoil
i plan to make the switch between dino and synthetic by running the valvoline blend for a few cycles
Florida240sx
During my a science fair project baotu 10yrs ago lol. Penzoil was the worse. It started to pop like bacon grease. Valvoline and mobil were the best ones almost a tie. and quaker state was 3rd best. This was all regular 10w-30.
nissanfanatic
Its false. People developed this assumption by putting synthetic oil in a leaky *** old engine that had been run on regular oil for so long. It leaked regular oil, but when they switched to synthetic, all the sudden the engine leaked a lot more oil.
Similar to using a glass with a crack in it, if you fill it with milk, you may have a small "ring" of milk afterward on your coaster. Fill it with water and you may have a mess. Now, is the water or the glass the problem?
You diagnose a problem, not a symptom. There are no pills for coughing, sneezing, and a runny nose, but there are plenty of pills for many illnesses that cause those symptoms.
get_up_mark
Car: 98 240sx se
i run castrol syntec blend. i change every 2gs and the oil has been good. i was sceptecle about going fully synthetic becuase of the seals. the drawback to blended oil is that if you need oil in an emergency you cant find it at most gas stations. i just always have a 5 qt jug in my car anyway and a spare filter. how long are you guys going between oil changes?
Craving4Boost
Florida240sx wrote:During my a science fair project baotu 10yrs ago lol. Penzoil was the worse. It started to pop like bacon grease. Valvoline and mobil were the best ones almost a tie. and quaker state was 3rd best. This was all regular 10w-30.
really? valvoline is cheap too!
GEO
Car: 95 240sx KA-T
ohh ok true.. Now when I do my next oil change, if I want to switch to vavoline... theres still gonna be some pennsoil in the pan casue it doesn't all come out, even if I jack it up on the drivers side... does it matter if it doesn't all come out and mixed witht he new brand oil?
one mroe question... now I have been running 10w-30 oil in the car, like said above, if I do the oil change and don't get all the old oil out... and I change the filter and pour in the new sythetic oil Mobil 1 oil.. will it matter if mixes with the oil currently left in the enginesince I can't get every little bit out? Also whats a good weight to run all year long of synthetic oil? 15w-40 ? 10w-30 ? WHat brand as well. THANKS
nismofly
there is so little oil left over it has no effect...after you changed it out again itll probably be out of the system completely
0wn3r
Car: 1997 Nissan 240sx SE track car (SR20DET, caged)
word on the street is that Royal Purple is just overpriced garbage.
should you even use synthetic with a turbo? i've heard of people who stay away from it after slapping on a turbo (non-240sx)
GEO
Car: 95 240sx KA-T
casue non-syntehtic oil is thicker.. I might jsut staynon-synthetic and run vavoline 10w-30
Craving4Boost
was it your choice or anthonys choice?
GEO
Car: 95 240sx KA-T
I was going to run something similar but he reccomended i run pennsoil 10w-30 just like he does, so i did.. lol
180sx
SYNTHETIC ISN'T THINNER look at diesel mobil 1 20w50 as thik an normal 20w50 thee main difference is blen synthetic or not , how oil acctually gets produced(tempatures /addictives ) etcits like buying oem parts vs non oem brands . same idea but better made
i ussually run 15w40 synthetic during summer and 10w30 for spring/winter time .
and castrol mobil 1 amsoil and redsoil are all pretty good choises for synth oils.
filters i use fram double guard / no problem i did hear that oem nissan filter help with pressure while at idle better/
WDRacing
nissanfanatic wrote:Its false. People developed this assumption by putting synthetic oil in a leaky *** old engine that had been run on regular oil for so long. It leaked regular oil, but when they switched to synthetic, all the sudden the engine leaked a lot more oil.
Best way I've heard it expalined yet...very nicely put.
