Engine oil
nissanfanatic
Car: 1992 Nissan 240sx SE
Synthetic IS thinner! Notably when it is at higher temperatures....
Quote »DISADVANTAGES OF SYNTHETIC OIL Cost is one big disadvantage. Also, can't really be used in an older engine due to the nature of synthetics, it tends to be a bit thinner at high temperature. This can exacerbate oil leaks and oil burning. Since the oil is more expensive, it makes the leaks/burning more expensive Another disadvantage is that synthetic oil usually is lower in viscosity at low temperatures. It will have a tendency to drain down faster. You may hear your engine more on cold startup. [/quote]READ: http://www.bobistheoilguy.com/motoroil.html
You can't examine this like you could spooge by putting some between your index finger/thumb and playing taffy with it. It goes slightly deeper than that.
Synthetic oil is "addictive"...esp after you see an engine that was run on it as opposed to engines that weren't. But what I think you meant was "additives," which if that is your worry, then stay away from oils containing high amounts of polymers I.E. 5w-30 and 10w-40. They tend to shear/burn at high temperatures leaving deposits that can cause several different problems. That is why I run 10w-30. Its just fine for pretty much anywhere that temps do not get below 0*F.
Colorado_S14
Car: 97 240sx Greddy KA-T
I use Mobil 1 10W/30 year round in mine. Synthetic is the only way to go in a high performance motor. They have a higher burn capacity and do not sluge like a dino oil. Get either Mobil 1, Redline, Amsoil, Royal Purple, or another race oil like Motul.
NateDogg
I just started using Redline 10w-30 on my stock 130k mi engine. Although, it has had a valve job, it does NOT burn oil even with 170+-5psi compression.
Just FYI..
