It's not always that simple man. I have a friend who bought a Z earlier this year. He maintains it as he should and it was fine until a couple months ago. I drove the Z for a week while he was on his honeymoon. It burned a lot of oil, but ran fine otherwise. It wasn't like this issue occurred over time. It was quite sudden. He is waiting to take it in and the engine will be replaced. I put 3 quarts of oil in the week I borrowed it. He had the oil changed about 1,000 miles before that and less than a day after I started driving it, I saw the oil pressure begin to sit too low. 3 quarts of oil burned in 1,000 miles is way too much for any motor under any condition.acoats wrote:Listen up everyone who has posted. There is nothing wrong with your engine. This is not grounds for a lawsuit. It is called a high-performance motor. The higher the performance, the increased likelihood of oil consumption; especially on motors with low mileage. Oil burning is very common during this break-in period. This is caused by all bearings and seals seating properly. This is also why "seasoned blocks" (40-60k miles) are more desirable for racing and forced induction; they are seated properly. I am a huge bmw fan, and they claim 1 qt. consumption every 750 miles on the M car engines. Guess what? My M3 with 108000 miles does not burn any oil between changes and I track the car. This is because the block and seals were broken in properly. It amazes me what people will ***** about when you a dealing with all the complicated workings of an automobile. Learn to turn a wrench or check a dipstick before you file your lawsuits.
The consumption problem seems to be more related to the 6MT. Maybe pulling oil when engine braking at higher rpms. Hard to say. Been reported on many G35 forums. Including g35Driver where at least 2 people are waiting for new engines from Infiniti.Road Ruler wrote:Yup, the dip stick is a pain but having no dip stick for the automatic transmission fluid is a bigger pain.
Yup, good points! Most accurate readings are doing them the same way each time. Tire pressure and fluid levels are best done first thing in the morning, each and every time for the best repeatable readings.C-Kwik wrote:A drain for oil from the head to the lower crankcase shares space with the dipstick. I learned this when filling oil once with the dipstick out. Oil came pouring out of the dipstick hole. I had usually filled the oil, then pulled the dipstick and left it out for a few minutes before checking. You usually get a much better reading then.
At least they didn't beat you over the head saying you should have checked it more often. Hard to say if some damage has already occurred. Sounds like you have been using a quart about every 600 to 700 miles... I would say that's excessive! Maybe your rings never seated.WdnUlik2no wrote:I got that same thing in my 06 G35 6MT.
I had been noticing that when driving there was this loud clattering coming from under my hood for the past month. It wasn't that bad at first and whe I first took it to Infiniti, they couldn't hear it. But yesterday it was real bad and I heard it all the time. I took it back and they finally heard it, They drained my oil and said they found I had no more than 3/4 QT of oil in the car. They contacted the Tech line and was advised to start the "Oil consumption test" They topped it back off at no charge and told me to come back in 1000 miles to inspect the oil again. They informed me not to change, check or other was tamper with the oil during this period.
I didn't even have 2900 miles on it when this problem started happening.
