johnlutz »
https://forums.nicoclub.com/johnlutz-u51360.html
Wed Nov 29, 2006 5:30 am
Having the exact same problem with my '05 G35 6MT. Didn't notice the problem until around 22k miles, when I heard the same knocking sound under the hood. Took it to the dealer, and said was 2+ quarts low on oil. They have started the oil consumption test, and I am now on the 2nd test. After the first 1,000 miles, I brought it in and it had burned 1 quart of oil. I'm sorry, but an engine should not burn through a quart of oil in one thousand miles (and during this first test, rarely got the engine over 4,000 rpm's). Will keep you posted, and will be interested to follow other people who are experiencing this problem as well. The dealer says if after the 3rd test, they determine that the engine is burning excessive oil, they will do a new short block (said the chances of a new long block are slim).
