Did it sound anything like this?pjl31445 wrote:As I pulled up to my home yesterday I heard a knocking sound coming from the back of the engine. Repeated a few times last nite. Only heard the sound when I was in park and idling.Took today off and went to my dealer, found there is a service bulletin ITB08-028A for the problem. They reprogramed the ECM and performed a N/C oil change using Nissan Ester Oil.Service manager said it is the strangest service bulletin he has ever seen.So far no more sounds.What is Ester Oil ?
http://www.youtube.com/watch?v=rdW6R_sWwtk
Telcoman
I think you can get away with using another ester based synthetic that will save you some money. I'm pretty sure Motul makes an ester based synthetic that will work. They go for less thatn $16/qt.pjl31445 wrote:As I pulled up to my home yesterday I heard a knocking sound coming from the back of the engine. Repeated a few times last nite. Only heard the sound when I was in park and idling.Took today off and went to my dealer, found there is a service bulletin ITB08-028A for the problem. They reprogramed the ECM and performed a N/C oil change using Nissan Ester Oil.Service manager said it is the strangest service bulletin he has ever seen.So far no more sounds.What is Ester Oil ?
No, the Motul is not API certified!!!Sentientbydesign wrote:I think you can get away with using another ester based synthetic that will save you some money. I'm pretty sure Motul makes an ester based synthetic that will work. They go for less thatn $16/qt.
I'm looking at one of their datasheets and it says API certified. The 8100 series is also advertised as "100% ester based synthetic".SteveTheTech wrote:
Thank you. I had looked for something when this oil first came out, but that was before the October 15, 2008 application.SteveTheTech wrote:So after some serious Googling I found the European Patent for Nissans Ester oil. I have spent a serious amount of time looking for something that breaks this down technically. I came across numerous threads on some of the other forums out there spewing crap from people who know nothing, please beware of the rampant misinformation out there!
Nissan Ester Oil Patent
It is pretty technical but if you read it it does (at least in my book) somewhat justify the cost, molybdenum is not a cheap element and the R&D behind this break though needs to be recovered.
Some of those oil posts were mine. The Nissan Ester bottle says it is oil, not synthetic, not semi-synthetic, just oil. A local dealer mechanic checked with Infiniti and was told it is conventional 5W-30 oil, with either an additional ester additive or multiple ester additives, and most likely made by Eneos for Nissan. He was also told Nissan has no plans to make just an additive available.Sentientbydesign wrote:On the BITOG forum and another infiniti forum, there are claims that the oil is conventional with an ester additive. There are also claims from owners that the oil did not solve the problem.
LOL I was reading your posts searching for this.notalk wrote:I have asked people at BobIsTheOilGuy.com to try and explain what makes the Nissan Ester oil different from others.
Telcoman
