Most of the 95 didn't come OBD2 they were OBD1.djmatt79 wrote:connect a OBDII scanner and clear the codes... then recheck to see if there isn't any hard code...
scanner will clear the codes... theres no button to turn them off...
as for the airbag... i couldn't tell you... you gotta check the circuit... if you dig through this site... you'll find airbag diagnostic charts or diagrams...
thats all I could say... if it helped...
