ngcharleshk »
https://forums.nicoclub.com/ngcharleshk-u44041.html
Sun Aug 27, 2006 10:23 pm
Hi,
I have a REdtop SR20Det on my S13, when I go driving in the hills I always get a feeling of a fuel cut at high speed corners especailly when I had to hold the throttle half way down in the middle of the turn. I later realized that "fuel cut" feeling only happens on 5500rpm and it happens at every gear. It goes back to normal when the engine goes pass that point, for example at 5600+ the car just runs normal again. I have an Air/Fuel wideband gauge and it normal reads around 11.0 on boost, however, when the engine hits 5500rpm and I tried to hold the rev right there, the wideband reads 10.0, which is running a lot richer than compared to 11.0 , and when I rev it up more it goes back to around 11.0 A/F ratio. Does anyone have similar problem, can anyone tell me what can the problem be? Can it be a bad MAF sensor? Why does it even feel like a "fuel cut"when its running rich? Is it really bad for the engine if I still drive it hard on the track?
Any help would be highly apprecaited.
Thanks X 10000
Modified by ngcharleshk at 1:39 AM 8/28/2006
