Here's the setup:
RB20det, internally stock.
RB26 ITB's
6boost manifold
KKK K3t 3070mga turbo
HKS 50mm wastegate
Z32 MAFS
Sard 500's
CarlH ROM tune
Full wire tuck
I started my build about 2 years ago and just finished up a few months ago, so the car sat for quite a while without any fluids in the engine. I swapped out the manifolds and got the valve covers powdercoated, but never tore apart the engine itself. Never took off the timing belt or touched anything internal at all.
So fast forward to a couple months ago. When I went to start her up for the first time, I filled all the fluids and cut the power to my fuel pump before I cranked it over. I cranked it for 5 - 10 seconds at a time about 10 times to build oil pressure and prime the turbo. After that I connected the fuel pump and tried to get it to start.
The car wouldn't start, so I sprayed some carb cleaned in the intake and it fired right up for a few seconds. traced the problem down to bad fuel, drained the tank/ put new gas and it started right up, but only with the MAFS unplugged and not running on all cylinders. Oil pressure and AFRs looked great
Turned out the 2 wires from the maf to the ECU were backwards, so I swapped them and it ran with the MAFS plugged in. But it still wouldn't run on all cylinders and I found out it blew the #1 coilpack at some point. This is when I first noticed a slight knock
Took it to a shop and they found the coilpack was grounding out, as well as the TPS not reading properly. They fixed both of these problems, but by now the knock was really bad and they said the engine needed to be pulled. When they cut the oil filter in half, they said it looked like it was filled with glitter.
I asked if the problem had anything to do with my ITB or turbo setup, and they said not likely at all. they also don't think it has anything to do with the tune. I was told that if I swap in a good block/head I should have no problems.
My biggest question is how could this have happened? I want to be sure that if it was something I did, I don't do it again. Should I send an oil sample off for analysis so they can tell me where the metal came from, or should I just tear the block apart to see what failed?
I also need to decide if I want to rebuild my engine(I have a spare block/head) Or if I should just buy an engine from an importer and swap it in as-is.
Any Ideas as to what kinda cost I'd be looking at for a rebuild assuming no extensive machine work is required?
How hard is it to do a rebuild in my garage with the proper tools and an FSM? The only thing I haven't messed with on my car is the engine internals.
Any advice is much appreciated. I've come too far with this setup to give up, so I'm hoping my NICO buddies can shed some light
