So I checked the mechanical timing the way Darius recommended and everything is lined up perfect.
Also cranked the engine with the coils unplugged and pulled the spark plugs like Joe said. The plugs weren't really "wet", but I could see moisture and they smelled like gas. I also checked the plugs on the working cylinders and they looked the same. I'm going to spin the CAS with the ignition "on" and listen to the injectors tonight.
Something I just thought of.....how do I check to make sure the cylinders are getting air? Given that each cylinder has it's own throttle body, this could definitely be a variable.
I know I'm getting spark
I'm almost positive I'm getting fuel
I just can't comprehend how those 2 cylinders aren't firing
