If i recall, there is some adjustment built into the motor mounts. you can loosen the nuts and lift the engine slightly and adjust it from side to side.Eikon wrote:Has anyone installed an SR before and had the trans not seem to line up correctly???
We dropped the SR in yesterday.. used the stock KA mounts (that engine was straight), but for some reason the trans just lines up a little off.. The shifter is about an inch toward the driver rather than in the center of the hole. We had a heck of a time trying to force the trans brace on.. those bolts just did not want to line up.
I'll post a picture later if I can.. but it's should be pretty easy to picture in your head.
Anyone had an issue with this before?? I just don't get it.. the mount are rubber.. so they should allow a little give... but to line up crooked??? It's not like we took the mounts off and put them on backwards or anything?
Any ideas?
I suppose it will work like this.. I'm a little concerned that the shifter will rub on the center console trying to get 1st and 2nd gear.. but it should be ok I guess..
Thanks for any input you might have.
So we need to loosen the upper mount bolts or the lower mount bolts? We left the KA mounts in the car because one of the lower mount bolts was pretty mangled.theclub wrote:You need to keep the motor mount nuts loose untill you put the trans bracket on, which will straighten things out. Mine was like that to, just grab the end of the trans and straighten it out , make sure to keep the weight suported by a jack and or jack stand.
