150k? thats not muchim going ka-t with my 166k 91 KA lol300hp@7psi?well i think you should stay away from RRFPR (FMU)seeing that you're gonna run 7psi (right at the edge for the FMU to be working properly) but i guess it'll be alrightS-afc is a "nice to have" if you're planning on using FMU (altho it'lll make tuning a biznatch)aside from fuel, dont forget about timing.. 3 degrees retard should be fine but its nice to have an MSD BTMfor 7 psi.. i think you dont need super duper expensive fuel management but if you're planning to go for more boost in the future.. why not go with standalones from the start?e.g.SDS standalonehttp://
www.sdsefi.com/prices.htmlYou will want the EM-4F for 4-cylThe EM-4E can be used, but it uses the stock distributor and requires a MSDbox and coil. The EM-4F is definitly the way to go, though.You'll also want the following accessories:Knock sensing, fuel pump relay, electric fan control (if you want electricfans in the future), 2-BAR MAP sensor, and maybe the fast-idle if you haveA/C. Also note the price of the Extra Injector controller as analternative.
after totaling the final cost.. i bet you wont even touch it LOL1600 bux is just too much huh?for now, im going with FMU since im gonna run only 5 psibut eventually, i will have to force myself to get this SDS standalone..
OR
you can make yourself your own EFI systemhttp://
www.bgsoflex.com/megasquirt.htmlA DIY EFI system I'm still investigating. looks kinda promising!
so back to the topicfor your setup that you're planning right now..i think it will be fine with370ccwalbro 255lph fuel pumphacked mafs (or Z32/cobra mafs)S-afcmaybe MSD BTM
good luck!
