Got a tricky one for you guys, I have a 1990 Max SE (163k miles) that cuts out completely whenever I shift the auto transmission into drive or reverse. It starts just fine and idles normal in park/neutral. When the engine is cold it will sometimes idle down very rapidly and cut out and occassionally bucking at about 200 rpm before cutting out. I have been able to lay on the gas with the engine cold and get it to stay on while in gear but it gets no more than 500 rpm but the engine bucks like crazy - then if I shift it into neutral and let off the gas the rpms shoot up to 1700 - 2000 rpms for about 10 seconds before coming back to normal (750).
When the engine is warm it cuts out when shifted into reverse instantly. All dash lights stay on as if I turned the ignition on without starting the engine. Check engine light does not flash nor do I get any codes from the ECU. Fuel Pump and TPS have been replaced to no avail. No vacuum leaks either. Timing belt/chain replace 8k miles ago. Is the transmission somehow connected to fuel delivery? Maybe its not getting the signal to keep sending fuel while in gear?
I've never seen anything like this before. Please help? This is my first Maxima (I'm a Saab Lover) and its ruining the experience already.
