Engine Cuts out when A/T put into Gear
marco2379
After all these problems with this automatic transmission, I am seriously considering doing a manual transmission swap, just to get the car going again. Do you have any pointers on making this type of conversion?
NISTECH
nah I have never had the pleasure of doing it. but on nissans it doesnt look like it would be all that difficult since most of the holes and mounting points are already there just covered up. It seems it could be done in a single day. lots to change other then the obvious pedal and shifter. The axles are different between the 2 , gotta change the flex plate to a flywheel, and the mount is different I believe.
