Well to get a USDM 2J motor you should find someone who needs your organs lolFlicktitty wrote:A few other motors i was thinking about was
-3.8L Turbo V6 engine out of the Buick GN and Regal T Type
-Try and rig a 4G63 onto a Might max? Truck trans.
-13B Rotory
-That or Call me what you will but i was thinking a 2.4L SRT-4 Motor would be pretty sick lol i have not the slightest clue if you could find a trans to convert to rwd.
True i give you that, but i've never been a big V8 powered guy, i'd rather spend more money and build a 2J/RB/SR/KA/4G63 etc.... then do a LS1 or LT1 or what not. but thats JUST MEWDRacing wrote:I did some more thinking on the 2JZ...Its nice but to get one to even close to 800 you're talking big money. I don't even care if you're not swapping rods and pistons. The turbo and engine managment alone is VERY expensive. Plus, you're looking more at 650 for a realistic stock internal motor. Not to mention you're only building a LAG machine...I've driven big single cars on lots of occasions, I'm no spring chicken. Thats why I'd lean towards a V8 swap. Right now torque is simply to fun to ignore. Toss a big single on it and well...you've got a winner in my book.
WD
zerothread?id=207033 It's almost done too. They will be offering it as a plug and play package with parts and labor for $6kevildky wrote:I havn't seen one in a 240SX yet which if more than I can say for most of the options
They may not be the most reliable motors but they do not suck.WDRacing wrote:Rotaries suck ***
I used to not be a big fan of them then i went to my now buddy's shop A-Spec tuning and good god they are awesome!redtop91 wrote: They may not be the most reliable motors but they do not suck.
Ya, I'm too greedy and want more than that, but am unwilling to put that much effort into my 23 year old motor when I could buy a newer more advanced motor with a lot better potential, especially a motor as torquey as the vh.evildky wrote:400 whp (so more like 500 crank) is the limit on the L6 with the stock cast pistons, put some custom forged pistons with an overbore and the LD crank and a few have exceeded 500 whp, quite a few in the 425-450 whp range, enough for a high 10 second pass in a lightweight car
i dounno about that one, personally i really like the SRT-4 motor setup. lots of tourqe lots of HP and easy to make 450HP on stock internals. I've seen 3 or 4 SRT-4's upwards of 600WHP which is pretty cool. If i had alot of money i might do it to a S30 after i have a 2J'd and a Ls7 powered S30 just to say i have a Neon on motorBoosted 70z wrote:FYI the srt-4 motor will bolt up to a certain Jeep tranny. But I wouldn't do this because I think the sr20 is superior imo.
The 2jz swap would cost just a much as getting an sr20 front clip and you trying to make 400whp with it. I mean mine will be in stock form fo a bit and it will run around 8k shop qoute me doing it 6500. ill be making around 400 with just that now add injectors, fp, single and ems and your talkn 600+hp.Boosted 70z wrote:
The 2JZ is a beast but its expensive and changes weight distribution.
God, I could only imagine how beastly of a vh45 I could build if I had that much money to through at it.TotalDPerformance wrote:
