All of the criteria are a match, so that should be me. If not screw the other personmtcookson wrote:Hmm... do you know a Jared in Indy that works at a performance shop? He mentioned to me that he knew of someone with a 95 VH with a broken piece that he wants to sell.
I was going to post about it here but if you're the guy then I don't have to now.
I know it sucks. I just have no desire to do it anymore. It would have been a ton of time, work, and money that I just don't have now. I am selling the car too. I am thinking of replacing it with an S4 about 6 months from now though.elwesso wrote:you're golden. Sorry youre ditching your project because of the plate....
Like I said I paid $280 for it, but I would like to get $250. I can have it taken to Ft Wayne over the weekend if you want it that fast, otherwise we'll have to figure out shipping price or pickup on it. the ebay link is still active, believe it or not, http://cgi.ebay.com/ebaymotors...MT:31elwesso wrote:How much you want to get for your Z trans.... CAn i have the 411 on it?
Not sure the exact mileage on the motor, but I was told it was low. I had a local shop track it down for me. They were told the mileage was low and that info was relayed to me. What "low" is, I have no idea. It is clean though on the outside. I am in Indianapolis. I can double check with RIU, but the only difference between the TT and NA transmission, as told to me, is the TT starter location is a few millimeters thicker than the NA (or vice versa).slownslurious wrote:how many miles on the engine, and where are you located? also I though the adaptor plate was for a Z32 TT trans not an NA.
isnt the main difference between the NA and TT flywheel the ring gear, not necessarily the face of the flywheel?ultrapulse wrote:I have the parts fiche for the z32. There are only a few differences in the NA v's TT gearbox. Differences I remember are: Front casting (I will explain), 5th gear part # (some years), speedo drive #, different input bearing # (some years ie probably doesnt appear to be a strength issue), and thats about it. One very good thing is that the TT flywheel, allthough bigger dia than the NA one by approx 5mm, will fit within the NA gearbox bellhousing. I have heard of some people claiming they have to grind small amounts from the inside, but not me. However you do have to space the NA gearboxes starter out by about 2mm due to the increase in flywheel dia, ie the NA box has a different face to shaft centre distance due to all z32 starters being the same. Both gearboxes have the same ratios, same strength, same size/bolt pattern, same input output splines etc, and very hard to tell apart. I also know of NA boxes used in heavy duty setups with no issues. So there you have it, either z32 manual would be good, infact the TT has nothing on the NA box when doing this conversion, apart from making a small spacer for the starter (or using washers like a mate has done in the past).Cheers.
i have had another look at both vg tt and non t housings i still cant see any diffewrences with the starter face or the mounting point, are you sure the differences arent in the starter motor?ultrapulse wrote:I have the parts fiche for the z32. There are only a few differences in the NA v's TT gearbox. Differences I remember are: Front casting (I will explain), 5th gear part # (some years), speedo drive #, different input bearing # (some years ie probably doesnt appear to be a strength issue), and thats about it.
Cheers ultrapulse ! That's the yellow 300ZX eh ? With his custom aluminium driveshaft ? I've spoken to him a few times.ultrapulse wrote:A mates zed did 340rwkw, drags it using hoosiers and beats it to within an inch of its life, yet with only a puck centre, all else std it hasnt slipped yet Remembering the zed TT isnt a lightweight car either. He also has done 2 years of burnout shows at Mystery Creek car show. So yes Im sold for a cheap grippy clutch.
A wee bit difficult, but the distance between the input shaft/crank centreline and that starter face WILL be different by about 2 or 3 mm!!gdz1la wrote:
there may be a small chance i have 2 tt or 2 non t boxes but one engine i saw, and the other was labled, and i saw the tt motor and twin plate it had
Yes all Z32 starters the same. Both yoke splines are the same, but forget the NA yoke, they are sh*t and wont hold the v8 abuse, basically the weak link in the na zed.The TT yokes are a little rare, but any TT AUTO front yoke is sweet if ya remove the little spot welded dust cover off it, ie a hammer wont do Basically ends up a TT manual one minus the dustcover:).slownslurious wrote:will an NA starter work on a TT transmission? and what about driveshaft yokes? will NA driveshaft yoke fit TT transmission?
I'm throwing all this in a car that is neither Q45 or Z32 so I am buying all these parts seperately want to make sure they all get along.
