The 850 is probably the best FWD, easy solutions, no can bus like the new ones, better launches, better to work with, lower weight and easy to find parts.The newer cars got "drive by wire" TB and a lot of electrical junk, hard to tune.The only negative thing is that S60 and V70N got a better engine if you want to go big hp. The 850 engine is used up to 600hp and after that you want the newer head.elwesso wrote:out of all the volvo's which ones seem to be the "hot" car to mess with??? That video of the 850 you showed sounds NASTY...
It seems the older stuff is choice to the new stuff...?
I got my 8:th 850T5 now and would not trade it for a newer. If you want to go fast, buy a 850 and if you want a nice daily driver, go newer models.Fastest 850 here ran 10.5 and fastest S60 13.2, the can bus system mess up the tuning and hard to mount a standalone.
