engine/boost stumbles near redline...!!!
sunnys14
Car: S14
i finally got my car running again after 2 bent valve incidents about 1 month ago... long story short, i had to swap out 2 separate heads. so finally, i got it started!
built motor with stock rods, 248 232 cams, 14psi, 480cc injectors on a t3/t04e with MSD BTM retarding .5 degrees per psi. i took it for a stroll down the street from a second gear roll, i punched it boost would climb (not the pull i expected out of 14psi) and near redline, about 5.5k rpms, the car would fall flat on its face like i hit rev limiter! it even sounded like revlimiter because i was bouncing off it. cant be the plug gap because i gapped the fresh plugs at .028...
3 blocks, 4 heads later... and im still having stupid problems. t-bolt clamped all the intercooler piping so there CANT be a way that i cant have boost leak... anyone figure this out?
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
at 14 psi .028" of a gap isn't goin to cut it. i'm running .025" gap right now and its barely cutting it.
sunnys14
Car: S14
alot of people are running .028 gap... ill try and gap them closer
S14tat
Car: 2007 FX35
1994 Acura NSX
if it still doesn't work try running some magnacor or taylor upgraded igntion wires. that was what made my misfire go away. also to see if it really is a misfire, just lower the boost to see if it goes away.
C-Kwik
with the amount of boost your running, if your coil is marginal, it may not be able to keep up. A stronbger coil or ignition amplifier may be necessary.
Florida240sx
What's your a/f ratio???
Chezedik
Car: 1991 Nissan 240sx
Have you tried running the coil straight to bat using a relay? There is a write-up on it in the sticky. Best of luck, man, I hope it works for you this time!
sunnys14
Car: S14
s14 coil shouldnt have any problems with power all the way up to 400whp from what ive heard...
MarkEmark
Car: fully-built '95 240sx KA-T
S14tat wrote:at 14 psi .028" of a gap isn't goin to cut it. i'm running .025" gap right now and its barely cutting it.
+1....before I gapped my plugs low, I had the exact same problem as
Sunny....also, maybe invest in some nice NGK Iridium IXs and a nice set of plug wires (8+ mm) and see if that helps...
MarkEmark
OT: S14tat: you've got mail!
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
C-Kwik wrote:with the amount of boost your running, if your coil is marginal, it may not be able to keep up. A stronbger coil or ignition amplifier may be necessary.
Im at 22 psi on stock s14 ignition with those thin oem nissan plug wires..!!
rn240sx
09 Ninja 650R
06 Suzuki S40
sunnys14 wrote:s14 coil shouldnt have any problems with power all the way up to 400whp from what ive heard...
Yes and no.
If it only takes 14 psi to make 400whp then yes its ok...
But if it takes you 35 psi to hit 400 whp... stock ignition wont support that much pressure.. It will just blow out..
sunnys14
Car: S14
well, i upgraded from regular NGK plugs to NGK iridiums. i can rev a lil further than 5k... more like 5.5k now. still doesnt feel fast as much as 14psi should feel... maybe theres some more boost leaks.
rn240sx
09 Ninja 650R
06 Suzuki S40
sunnys14 wrote:still doesnt feel fast as much as 14psi should feel... maybe theres some more boost leaks.
Does your boost gauge read 14 psi..??
PencilShavings
Car: '91 240 hatch
isnt 14psi from a t3/t4 a lot for 480cc injectors?
crzycav86
Car: 93 Nissan 240SX KAT
I agree with this.
rn240sx
09 Ninja 650R
06 Suzuki S40
PencilShavings wrote:isnt 14psi from a t3/t4 a lot for 480cc injectors?
yes and no. It all depends on the tunning and turbo specs. Is your boost gauge reading 14 psi..??
Next question is if u did ever hit 14 psi and know what it feels like and now u r still hitting 14 psi but it doesnt quite feel the same, then u obviously have a problem somewhere.
sunnys14
Car: S14
boost gauge does hit 14psi. i could never really tune it so afr's would be all out of whack. ive never hit 14psi, just the wastegate is set at 14psi.
sunnys14
Car: S14
i also tried to reset base timing. but everytime i unplug the TPS while the car is off, then turn it back on, the car would start but then just die out... it will only turn back on and stay on if the TPS is plugged in
sunnys14
Car: S14
i also threw a CEL which was code 21 (ignition signal). would wiring a MSD BTM which caused me to cut a transitor, caused me to throw this code? internal coil... weird stuff
rn240sx
09 Ninja 650R
06 Suzuki S40
sunnys14 wrote:boost gauge does hit 14psi.ive never hit 14psi, just the wastegate is set at 14psi.
Is it me or did that just make no sense...
sunnys14
Car: S14
ok, listen up, wastegate is set at 14psi, boost gauge hits 14psi, but it feels like 2psi...
rn240sx
09 Ninja 650R
06 Suzuki S40
Where are you tapping off of to read this 14psi..??
sunnys14
Car: S14
brake booster
Craving4Boost
Car: 91 240sx fastback
whats the update on your car
sunnys14
Car: S14
turbo is bad, mega super shaft play, wont even build boost, compressor blade sounds nasty, turbo seals probably bad because i get blue smoke during deceleration...
S14tat
Car: 2007 FX35
1994 Acura NSX
well atleast you found your problem. that probrably helps you sleep alittle better at night.
rn240sx
09 Ninja 650R
06 Suzuki S40
sunnys14 wrote:turbo is bad, mega super shaft play, wont even build boost, compressor blade sounds nasty, turbo seals probably bad because i get blue smoke during deceleration...
But i thought u said the boost gauge is reading 14 psi but now your saying that it wont even build boost...
You keep changing stories here..
sunnys14
Car: S14
things change over the days man...
sunnys14
Car: S14
turbo is dead for sure now, i can hear the blades hitting at idle... i just picked up a garrett t04b 50 trim .48 AR for 400 bucks. so im now just waiting to get it delivered to me so i can slap it in.
