engine/boost stumbles near redline...!!!
Craving4Boost
Car: 91 240sx fastback
such a small AR...you sure it will do good with 14psi
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
Craving4Boost wrote:such a small AR...you sure it will do good with 14psi
im hitting 22 psi with my .48 a/r
May not be efficient up there but its holding.
nb07bcar
I had the same problem. Try seeing if there is oil on you spark plugs. I also had that problem with a stock maf.WHen I upgraded it was just fine. Also do you have a 5,500 rev limiter in the btm?
sunnys14
Car: S14
i pretty sure it doesnt have a 5500 rev limiter on the btm because i got it from Craving4Boost. unless he put a 5k rev limit pill in there...!?!
Craving4Boost
haha naw i didnt...im not sure if BTM even offer rev limiters
nb07bcar
Mine has the little chip that you can change. I have mine a 7000.
