engine alternates between perfect and boggish
seanman
Car: 1989 Nissan 240sx
Engine: s13 sr20det
Parts: front mount greddy, mechanical boost control, hks ssq, new spec stage 2 with new spec flywheel, walbro 255
Problem: So i've had the engine in the car for a few months now, and i've noticed that the engine will either run perfect and feel awesome, or it will run kinda boggish. By this i mean it doesn't have the same response when i accelerate. if you could imagine the feel, it feels like theres too much fuel. Also i can smell extra fuel when i drive, its not super overwhelming, but smelly enough to where anyone would know it smells like fuel.
Theres no specific situation when it feels boggy. Usually i'll start it up and it will either run well or not as well. And i've noticed that when i get off the freeway running about 80-85 mph it runs better like the higher rpms would force out any extra fuel or something. any input would be great.
Oh and i have a nismo adjustable fpr and a autometer gauge to go with it but i haven't installed them yet. What do you guys think?
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Id say get the FPR installed.
What spark plugs are you running, what heat range are they, and what are they gapped to?
How much boost are you running, and have you checked your ECU codes lately?
What octane fuel do you run?
Do you have to crank the car abnormally long when its cold?
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
FlatBlackIan wrote:Do you have to crank the car abnormally long when its cold?
Just wondering why that particular question?? Just wondering..The rest I understand, this I do not. u seem to really know the ropes, thats why I ask.
Than ks
IanS
Than ks
A leaking fuel injector, injector O ring, or pressure regulator can cause odd and sometimes intermittent driveability issues. The fuel will not always leak externally, but pressure in the rail bleeds off, so cold starts require an abnormal amount of cranking.
Koshin
that makes perfect sense, you know your sh_t.
seanman
FlatBlackIan wrote:Id say get the FPR installed.
OK! sorry i haven't been able to reply at all. I do not know what the spark plugs are or what they're gapped to. They're the original ones that came in the engine. im at 10psi with 91 octane pump fuel. And she starts up easily no matter what the condition. Ill be heading over to NAPA tomorrow to get fuel line and connecting pieces for my fuel pressure gauge.
IanS
I would recommend picking up a set of BKR-7 NGK spark plugs, either copper or Iridium if you can get it, stay away from platinum. Gap the plugs to .030.
Also, check you coilpacks for cracking.
Do you have any ECU codes?
seanman
idk if i have any ecu codes. i dont have the tester for it. I'll def throw down for some new plugs tho
IanS
You don't need a tester, just turn the screw on the ECU then count the LED flashes.
seanman
i didn't know there was a screw... where is it?
IanS
seanman wrote:i didn't know there was a screw... where is it?
On the side of the ECU, there is a little hole, there should be a sticker pointing to it, you can search for the procedure to pull codes from a redtop ECU.
WoolyS14DET
Car: 1998 Nissan 240sx w/SR20DET
Sounds like you got this under control !!!!
seanman
lol yeah, now if i could just find TIME! thank god my 2nd job's ending next week
