not at all. this is on the hood itself. its meant to drop down after the plastic pins melt off due to a fire, and attempt to smother it out. it also helps with absorbing some heat from the header during very-very hot summer days in stand still traffic.followingnfront wrote:I think the most they probably do is deaden some of the engine noise
Right... I just always thought of it as doubling as sound insulation as well since it is a layer of insulation that the engine clatter has to pass through to get to the hood, and ultimately out of the engine bay.ImStricken wrote:not at all. this is on the hood itself. its meant to drop down after the plastic pins melt off due to a fire, and attempt to smother it out. it also helps with absorbing some heat from the header during very-very hot summer days in stand still traffic.followingnfront wrote:I think the most they probably do is deaden some of the engine noise
sound travels through the firewall. its got all the holes where sound sneaks through.followingnfront wrote:I just always thought of it as doubling as sound insulation as well since it is a layer of insulation that the engine clatter has to pass through to get to the hood, and ultimately out of the engine bay.
Just wondering, does it keep engine warm during winter?ImStricken wrote:not at all. this is on the hood itself. its meant to drop down after the plastic pins melt off due to a fire, and attempt to smother it out. it also helps with absorbing some heat from the header during very-very hot summer days in stand still traffic.followingnfront wrote:I think the most they probably do is deaden some of the engine noise
lmfao sure. nice and cozy LOLzengshengliu wrote: Just wondering, does it keep engine warm during winter?
