Thanks for the pic, it really helped.
So I went to my driveway in the dark and use my flashlight. I have that protective covering too. Personally, I I believe it's some heat resistant/ stock hoodliner insulation thing.
But yours is not some burned hole, it's freaking caught on fire and practically burned the whole thing! Not some little hole.
It belongs there, the dealer should replace it. Plus look into why it burned. Never seen that before~
I really thought these things are not suppose to burn because it is suppose to act like a firewall too.....
ps- just did research online and found this...
the true function of the hood liner. It's a fire blanket. If the engine catches on fire, the fasteners to the hood melt and the blanket drops smothering the fire. That's the theory anyway. Given how much oils has gotten on most of them, somehow I don't think it'll actually put the fire out but, it might give you a few additional seconds to get out before the car becomes engulfed in flames.
