Uhh, turbo maps are only for the compressor side. I could not tell you the spool curve/rate/start/profile of any of the 8 turbine setups (4 for each, 2 each for t3 and t2).Loveless wrote:what if it's the .86 a/r for the gt2871r instead of the .60?
hehe I don't understand this thing at all... it's all picasso to meNowhere wrote:Uhh, turbo maps are only for the compressor side. I could not tell you the spool curve/rate/start/profile of any of the 8 turbine setups (4 for each, 2 each for t3 and t2).
You're comparing coke bottles to wallpaper.. The .86 is a turbine setup for either one for the t3 mounting flange.. The 60 is the compressor side..Options:compressor/turbine a/r ratios..gt2540r.70/.63, .70/64, .70/.82, .70/.86GT2871r.60/.63, .60/64, .60/.82, .60/.86
I'm doing more searching on the net, I'm seeing different trim levels..... Rrrrrrrrrrrrrrrrrrrrrrrrrrrrrr.....
Post back in a while with more facts..
The differences between the TURBINE .6X and .8X series seems to be ~~ 40 ~ 60 TOP END horsepower..
I agree on the .86 being WAAAY TOO HUGE, but with the .64???CA19DET wrote:dunno, but the .86 GT2540Rspools at over 5k rpm on the CA and the GT2871R seems to spool way quickler on every other engine compared to the GT2540R so my money is still on the GT2871R in all trims and A/R to be better than the GT2540R, i was about to buy a GT2540R and swaop on a .64 A/R GT25 Trubone and run it with an external gate, but seeing dynos of the same engines with booth - the obvios choice is the GT2871R...
Nope, The HKS GT2540R is by the GARRETT GT2876R turbocharger.HKS USA acctually "owns" the "GT2540R"... It's a custom HKS product..Loveless wrote:so what does this mean? say it in plain english...
GT2540R owns gt2871r?
They don't list a compressor map on the new 2871r "15" model.. I'm curious as to what's soo good about it vs. the others?CA19DET wrote:IMO Garrett doesnt really reccomend the GT2876R aka GT2540R, it strongly reccomends the GT2871R
GT2876Rhttp://www.turbobygarrett.com/...1.htm
GT2871Rhttp://www.turbobygarrett.com/...5.htm
i think the newer 71mm turbine is the more efficient of them all. the 76mm one may be bigger but tis laggier and really doesnt make much more power combined with the compressor onteh GT2540R or GT2876R or whatever,,,
IMO get the GT2871R - 472560-15(.64 A/r Turbine)
71mm is the exducer diameter on the compressor not the turbine, but I do agree it is a very eff turbo.CA19DET wrote:IMO Garrett doesnt really reccomend the GT2876R aka GT2540R, it strongly reccomends the GT2871R
Hhe, I meant to say compressor. The turbines in the GT28 series are all the same, ....... the .64 or the .86......rbsileighty wrote:71mm is the exducer diameter on the compressor not the turbine, but I do agree it is a very eff turbo.
A HKS USA GT2540R or a GARRETT GT2876R?? What a/r on the turbine (big or little??)rbsileighty wrote:I have ridden in WRX that is equipped with one
??? The Eff islands and ##'s are listed on garrett's site (the 1st picture I posted does not show eff ##'s... Look @ the links above for the GARRETT maps on the gt2876r and the gt2871r)The HKS USA GT2540R does not have a compressor map.. Any reference I make is to a garrett turbo, it's about 1,500 cheaper!!rbsileighty wrote:The key to these two turbos, in my opinion, is eff and balance. The one thing not shown on the GT2540 or GT25/40 map (whatever it is) are eff. numbers...
The specifications between the GARRETT gt2876r and the gt2871r are pretty close.. The 2876R does flow more though.rbsileighty wrote:This along with the energy required to spin a large compressor in an unbalanced turbine/compressor match-up...
The HKS or garrett??rbsileighty wrote:as seen in the GT2540...
Again, the HKS or Garrett?? Garrett Does NOT make a gt2540r..rbsileighty wrote:The aussie guys who have run this turbo are not a big fan of it...
Those HKS USA units are EXPENSIVE!!!!!!!!!!! Waaaaay too much money for my blood..rbsileighty wrote:they tend to opt for the GT2530 from HKS instead. The GT2835 from HKS is also a good turbo, but it is more like the GT3071R than the GT2871R from the numbers in the comp and turbine.
I agree 100%The HKS is waaaaaaaaaaaaaaaaay to expensive.What are your thoughts on the larger compressor setup on the GT2876R though????rbsileighty wrote:If I were spending the money... I'd say GT2871R over the HKS GT2540 hands down.
Crank powahrbsileighty wrote:Crank or wheel hp?
