Sweet!Encryptshun wrote:Bump! Car is down on all 4 corners and has a new windshield. Pics to come tonight.
What? It's only been 13 months!Hijacker wrote:It's about time
Yeah, I'll stop by Texas on my way home from work tonight...d!ck wrote:if your car is done before mine im going to need you to come over and help me finish.
Please elaborate. I am adjusting the height by removing the two 17mm lower bolts, tilting the spindle out of the way, rotating the lower housing upward, tightening the retention nuts, reassembling, removing the jackstands and taking a gap measurement with the suspension under full load. I am jacking up the car from the side and it's the side-skirts that are not granting enough clearance. Is there a better way to do it?Hijacker wrote:Blocks of wood under the front tires.
Also, you can do the slower way of jacking by going from the side and jacking on the frame rails.
^^thats what i do, get 2 2X4's and drive up on them.... you should have enough room to clear the jack.Hijacker wrote:Blocks of wood under the front tires.
Didn't say have to. Said did. So one way is that you back the bottom retaining nut off from the lower housing, you grab the threaded part of the coil body and you screw it down into the lower housing until the retaining nut is again flush. Then you cinch it up. However, what you are doing is unscrewing out of the top as you screw into the bottom, effectively keeping it at the same hight. So (and this is why I asked for help), the only way to avoid that as far as I can tell is to unbolt the lower housing, disconnect the brake line clip, and then screw the lower housing up onto the coil body.tramp_drift240 wrote:you have to completely disconnect the coil from the spindle to adjust the height?
Bart, what you do with your car, in the privacy of your own home, is no one's business but your own. Personally, I prefer to jack from the front, as jacking from the rear requires that I either dislocate my shoulder or perform a very painful tuck maneuver and stand on my head.Hijacker wrote:Are you having the same clearance issues if you jack from the front? A lot of times, I'll jack off the front lower core support ...
You wouldn't want to remove the ABS actuator (that's the metal cyborg-looking mechanism by the wiper motor) because your hard lines run into and out of that even if your ABS is disabled. You'd have to re-run (or splice) the lines in order to bypass and remove the actuator assembly. I don't think it weighs very much and it may very well help to slightly cool your brake fluid through passive radiation, so unless you really really want to, I'd suggest leaving it and just disconnecting the wiring.kevinphan wrote:Hmm that sounds easy could you possibly take a close up of it?
Is it possible to remove the ABS pump(?) that's right next to the wiper motor. I hope I'm correct haha.
