deviousKA wrote:There is no publicly available software with the correct settings for the ka24e timing output, there will be in a couple months but thats about all I can say, be patient.
Timing along with all of the other consult data is streamed out the ecu with a serial/uart function of the processor. This data must be parsed and converted correctly before being displayed, in the software. Check consult protocol PDF for more information.
The offset for timing is changed for a couple different nissan ecus, most are 110-value, some are 70-value, the ka24e is 80-value.
I cannot release my work because it is bound in a new software application I am betatesting for the US market. No other software will be able to take advantage of the information, but still I cannot release much more than this.
So it's software you are working on. I knew it was something. Good for you, I hope it does well.
Untill then, what do you mean by timing offset?
If there is currently no software that correctly handles the KA24E timing, as you stated, don't you think it would be good to make people aware of this instead of suggesting that it's a piece of cake.
Besides, using Consult requires a Stanza ECU, Stanza bin & ADR, special cable and modification to the wiring harness. Not exactely a trivial matter.
I understand that you want to build interest in DIY tuning and when your software is ready I'm sure it will rock. Perhaps you should also consider a bundle containing the aformentioned parts. But untill then, it isn't fair or honest to drop vague and ambiguous information suggesting that tuning these motors is so trivial and well established when it is neither - at least not yet.
At the very least this will cause people to waste a lot of time & money, as I have. It may also result in blown motors. This is not the best way to buld interest or customer confidence.
How about simply suggesting that people wait for the software.
