electronically controlled suspension on 99+ Y33 touring edition
Qfortyfiver
ok guys sorry for all the quesitons.
I did a search on this topic only to find nothing.
anyone know anything about this feature ? is it a adjustable height feature ? I doubt it.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Shock valving.
Try the search tuorial. Not sure whre it is stickied now. Should be here.
96Qowner
Car: 1996 Q45
Try a little harder, Qfortyfiver. I searched post bodies in recent threads for the terms y33 suspension and found this on the second page:
Y33 ADJUSTABLE SUSPENSION DESCRIPTION
Also new for 1999 is an Active Damper Suspension, available as standard equipment on the Q45t. This system offers electronically modulated shock valuing control with SPORT and AUTO driver selectable settings.
The system uses real-time, independent 4-wheel shock absorber damping force regulation in response to input from vertical G-sensors and steering angle sensors. Signals from these sensors are sent to the system's computer control unit, then matched with vehicle speed. "Instruction" data is then sent back to actuators above each individual shock absorber, which immediately adjust shock absorber damping force.
The system helps eliminate excessive body movement, such as in hard cornering, braking or acceleration. It also helps improve tire-to-road surface contact for greater stability and enhanced handling control.
With the two adjustable settings, drivers can chose between a softer, more comfortable ride or a firmer ride with more road feel, depending on road surface, traffic and climate conditions or personal preferences.
zerothread?id=143490
Most questions have been answered over the years. Some of us will gladly take our own time to find these threads for you, but you could do it, like, right away, if you'd give it a try.
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
very nice of you to at least post the information for him on here, and not just instruct "search."
I just find it infinitely annoying that people on here take it upon themselves to be "search" vigilantes. If you don't want to answer, or it's been answered, then don't answer it.
Some people just are not that competent! Some people are not familiar with computers! Some people don't have time to sift through pages of results! Some people don't know how to "use" a forum, much less it's search feature!
Seriously, like the saying goes...if you don't have anything nice to say, don't say anything at all.
96Qowner, this is not directed at you since you WERE nice enough to search FOR him and post the information, so please don't think I'm flaming you.
People just need to calm down and remember the PURPOSE of this site...to CREATE discussion, NOT to stifle it.
Qfortyfiver
the search criteria for NICO is not as refined as other boards.
if you search via username, u mind as well forget searching at all.
also the fact that it is not split between g50 and y33 is not good, u have to go through alot of stuff in order to find what your looking for.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Qfortyfiver wrote:u mind as well forget searching at all.
We have a lot of complaints about u but he never posts.
The search tutorial is blank because Surpass Hosting is run by a bunch of incompetent alcoholics.
zerothread?id=105819
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
paranoidjack wrote:very nice of you to at least post the information for him on here, and not just instruct "search."
Amen. I'm always impressed with people providing actual answers but think that just saying "search" is a pathetic attempt to sound like an expert.
Even more detailed info is in the searches than a rehash of old stuff. The dilution of information as it gets repeated.
