Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Wed Apr 21, 2010 8:46 am
The question is not does it work but does it add any value [acceleration] vs cost vs stress on alternator and other systems.
Necessary to understand the relationship between kilowatts and HP, electric motor efficiency, and how much power is needed to compress [137 cubic inches of intake air per revolution of engine]. The peak air gulp per revolution occurs at ~ 4,000 rpm [by definition where the torque peak occurs].
1.0 psi is ~= to a 6.8% boost in air flow and/or power increase.
Remember all engines are already superchargered to 14.7 psi by the Earth's atmosphere. 15.7/14.7 = 1.068 [above].
The major problem is how much added heat [from supercharger electric motor in air path] degrades the boost [1% per 11F for all air not just boosted air], so if all air goes up 75F all the value of 1.0 psi electric boost is wasted!!!!!!!!!!
Important to measure outside air temp vs after compressor temp vs time.......the longer the charger is on the worse the problem gets after 1-2 seconds.
Understand that torque/acceleration is a cube root function so 6.8% boost yields at best 1.88% improvement in acceleration.
For those 1995 and older Q:
Remember Nico/Wolf/Stillen ecu reprograms are best bang for buck since they release 20>30+ Torque/HP from built in safety reserve [depending on KS and fuel quality].
