Any suggestions on what to check or how to repair?
You're probably hearing the motor trying to work. Is the click coming from below the seat? Since all the other functions work I wouldn't suspect a fuse. Chances are good there's an obstruction in the seat track and it's jammed. Seats are easy to pull- a couple of trim pieces and 4 bolts. Try removing the seat to inspect and clean the tracks.miami3 wrote:......I do hear a noise when I push the forward/backward button (relay?) but there is no movement......Any suggestions on what to check or how to repair?
I had a dime stuck in the driver's seat track of my previous car. The dime got bent pretty bad and was really stuck. Once I removed it, everything went back to normal.goody90q45 wrote: Chances are good there's an obstruction in the seat track and it's jammed. Seats are easy to pull- a couple of trim pieces and 4 bolts. Try removing the seat to inspect and clean the tracks.
