2001 pathfinder power seat
Pathman2001
Car: 2001 pathfinder 4wd
2006 Nissan Titan
2001 pathfinder se 4wd How do i repair the power driver seat control, as of now the front to back movement has stopped, i can hear the switch clicking ?
nguyenmd
Car: 2001 Nissan Pathfinder LE
Get underneath the seat, look for seat motor and use like the handle of the screwdriver, tap on it a few times should fix your problem . Keep tabbing it. your seat will work again.
Pathman2001
2006 Nissan Titan
will do it ,and let you know my 2006 titan failed a PA inspection because the wipers were bad, The dealer is really grasping at straws, $35 for new ones or I can't have my truck back. now this is a 2006 model with 20,000 miles and always garaged go figure.
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
definetly try tapping the motor like nguy said, if that doesnt work you'll have to get a new one
Pathman2001
2006 Nissan Titan
what do you know, I was shocked tapped the dang motor and it worked, thank you very much..........
ARKQX33V6
If tapping the DC motor and then it works you are due for brushes, but can you get small brushes for that motor. Another thing could be lack of use, with 2 drivers my QX4 is over 13 years and the seats are always being adjusted. Go to a motor rewind shop if brushes are needed.
mdeisenhauer
Car: 2001 infiniti qx4
The hammer method works because more than likely your brushes are worn irregular and that allows them to make more contact with the commutator. This was the case with mine, I could tell that going all the way one direction would kink the brush not allowing it to go the other way without tapping it. If you're mechanically inclined do what I did and find a maxima/I30/pathy/qx4 and maybe others in the same year range from a junkyard/pick a part and change the motor out. I got one from a 2002 maxima that fit my 2001 qx4. The motor plug was different though. On a maxima/I30 they have a two wire plug, the qx4 has a 5 wire plug. The extra 3 wires for the qx4 went to a little circuit board that fit in the top of the plastic motor housing. The maxima had the same motor housing with the notches for the circuit board. I switched brushes and the plugs and im back in business for 20 bucks and an hr or so of work.
Or you can go to a pick a part and find the motor grab some brushes and put them in your pocket. The damn things are tiny though.
