Lost_To_A_K-Car wrote:Originally posted by Julio Bro! "]The electric fan is engine
condenser
temperature based, it turns on if the engine
condenser
reaches a certain temperature
s14=pimpin' wrote:hey, thanks alot guys
still a little confused though. Julio says its not worth it, but I'm not tuning my KA until I've come to a conclusion on what turbo to use. I figure its a universal fit, so even if I do swap, I can use it on another motor, correct? It is a nice fan, although I am buying it used, so I will have to take a look at the connections, thanks again.
240sxer, are you currently using a fan? Thanks for the info, the main reason why I wanted to replace the stock unit was to free up space so I can use my homemade CAI, the stock fan is so big, and ordering from Injen is no fun!!!
cya guys
doctorj240 wrote:I guess this makes sense but the best sports car isn't running through stop and go traffic with no air flowing through the radiator on hot city streets. They're zipping around at 150 mph flowing plenty of air through the engine bay.
Oh yeah... I know there are turbo 240s running only a 12" fan. To be safe though I would not go with a 10 if you plan on upgrading, go with at least one 12".
R240NA wrote:The fan turns on low speed at 202 degrees, high at 212, OR when the AC is on. Your fan should be on whenever the AC is on. That fan is fine for cooling on it's own, but an upgrade to a pair of fans, or a larger unit will cool more.
Lost_To_A_K-Car wrote:Originally posted by Julio Bro! "]If this is for sure, then it should be a combination of engine and A/C temperature, after all it's installed behind the radiator and complementing the main fan.
It is for sure, and it's not dependent on the engine temperature.
I've been working on AC units for almost as long as I've been working on cars.
Is there a temp sensor on the condenser or it's lines? Where?
Check your FSM, it's noted in there. HA-42 in the 1990 manual, I don't know what year you have.
240SXer wrote:
Also, mine appears to have some sorta stock electric fan that's in front of the clutch fan, i've never seen it on, but what's that about? Is it for when the AC is on?
David.
SRJesse wrote:I have 2 electrical fans on my sr20det setup. The only "con" that I can list is if the engine is still warm when you park it and shut it off, the fans will run off the battery until the sensor reaches a point and they shut off (depending on temperture). You can get a relay at radio shack or any electronical store for like $5 and they will shut off when you shut your car off, that way you get rid of the only "CON" I can tell you about.
Hope this helps with your final decision. Good luck.
TooSicks wrote:I've been considering switching to electric fans, as well as an electric driven water pump. I'm thinking about 2-12" with a standalone thermostat system and also an electric water pump drive motor. Summit sells an electric motor with a drive belt that drives the water pump on a chevy 350 but i'm sure i can make it work on my '89. has anyone else ever seen or used an electric water pump on a 240?
In my experience and opinion I think the electric fans are more reliable than a belt driven setup, as i have had many mechanical fans shed blades,crack and warp, and eat fan clutches with regularity. My toyotas, hondas, and my ford tempo all used electric fans and I never had any fan related cooling issues with any of these, even when driven hard and kept on boil, at the strip, on the roadcourse, or in rally racing conditions. I haven't had much nissan experience but in my general experience the only fan problems I have ever had were with mechanical setups. my chevy venture actually shedded a blade at 75 mph on the highway, dented the hood, and dstroyed the water pump whichj led to an extremely rapid temparature increase that caused a head to warp.
