electric fan
Emperor_Tha
need help install the wire. i got flex-a-lite.
boj240
Car: 93 hatch sr
get the exact wire... one wire to the battery, one wire to the fuel pump fuse.. in the box... you might want to set up a relay for later but that will get you started
Emperor_Tha
then it will run all the time. i dont want that. any alternative?
CoupedUp
Car: 1993 Coupe
When do you want it on?
Emperor_Tha
when the thermostat open. or earlier.
Modified by Emperor_Tha at 8:18 PM 6/13/2007
CoupedUp
Car: 1993 Coupe
Than you need to wire in an Adjustable thermostat.
Emperor_Tha
ok thanks, do u know how to set that up?
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
Instructions will come with the adjustable thermo kit. They vary depending on relay setup and power source. It is usually only 5 wires with a relay. Cake job
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
a good old switch has never failed me, as long as you dont leave it on when you shut the car off.
Emperor_Tha
okay i just pick up DIF dual fan contoller it has the instruction...thanks
Emperor_Tha
what would u guys perfer the set the fan setting temp? the lowest is 150 degree
IanS
180 F
