That guy in the picture has a/c.... First off I noticed the condensor hard lines, then he said he replaced the mech and condensor fan in the text
And his setup is a bad idea as only 60% of the rad is getting cooled. In the florida heat my 16 fan mated like that caused it to overheat with the ac on quickly in traffic.
Another way to use the condensor fan or tie into the condensor harness, yet have it run continuously is to take the ac fan low relay and cut the ecu input wire (going into the relay) and ground it (the side going into the relay). This way it only is on with ignition on, though with just ign on its still on hehehe great for in between strip runs or auto-x laps though, but not so good if your just chilling in a lot listening to tunes, sans car running. Thats why they made switches though.
I personally use dual altima fans that have dual speed settings, but they dont fit without some heavy hacking of the fan assembly. I have one wired to a new relay always on on low (a bullet connector is between the fan and relay to allow me to cut power on cool days of car off ignition on sits) and the second just took the role of my ac condensor fan. The always on fan is on the drivers side as well so that I have air running past my header durring idle time.
