You did a Chicago summer without AC?!?! That is dedication. The J30 is the hottest car (literally and figurativelyEswift wrote:uses a powerdyne bd550 head unit right where the AC compressor is supposed to be. most people dont want to do it because of the AC loss, which is understandable. with nothing more than turbo injectors, the supercharger, and a JWT TT ECU (which isnt even correctly mapped) 291 HP at the wheels is comfortably realized with no detonation. 2 guys have been running this setup for over a year now. ash powers' new "zemulator" will allow a much more robust tuning method for the ECU maps.
i did a summer in my J30 with no AC to see if i could handle it, and i will be piecing together parts for this job when i get all the details...
lets see if i have any pics...
VimyJ wrote:You did a Chicago summer without AC?!?! That is dedication. The J30 is the hottest car (literally and figuratively) that I have ever been in. ....... You better get a spoiler, brother, or you're going airborn.
Eswift wrote:all the NA 300zx guys just seem to trade in for a TT, or to swap in a TT engine. Hopefully i will get started collecting everything i will need when it gets warm here again.
Eswift wrote:i did brave the chicago heat last summer, as forced induction on the mind can do crazy things to one's willpower...the black on black sure didnt help things either...
somehow or other my plain old J30 has the J30t spoiler, which i think was a hint of what was to inevitably come....
heres an install pic of craig channer, to my knowledge, the originator of this VG breed...(that was his dyno also)
Movingviolation240 wrote:I live in FL and have no AC due to a motor swap, THAT is dedication.
I did the electric fans on each 240 I've owned. Never had an overheating problem with any of them that wasn't my fault (adjusting the temp switch wrong) and I've also never overtaxed the charging system. I can say that the HP increases were a lot more than you'd expect. Heck on a Z32 the UR pulley gains like 22hp from less drag on the crank and less rotating mass. What do you think a big fan swinging through the air and a heavy clutch are? drag and mass.
And one last thing (this is just 240 experience but should be the same) the car will run cooler with twin permacool fans and their shrouds in place insted of the stock mechanical fan.
PaulOrlando, FL
VimyJ wrote:Have you made an estimate about the cost? Damn, 291 rear wheel horse power in a J! Your car is going to be unbelievable! Should be able to handle it though.
Eswift wrote:not that there is anything with staying on the safe side, but 6000CFM is huge! how did you determine that figure? (most aftermarket EL fans pull 2-3k max...at least that i have found so far)
Eswift wrote:My transmission is a little hairy already, but i am confident it will hold that much power for at least a little while. Life left will depend on previous and future abuse. If it fails on me i will have to go with the 5 speed conversion. Im pretty sure the craig has a stock clutch on his 300zx with the supercharger. Assuming the gearing systems are designed between the J30 and the 300zx with a similar factor of safety, if he hasnt seen a problem in a year, i probably wont either.
