Spacers have gaps for old studs. Bolt and play.e464sho wrote:Did you have do any modifying with the oem studs to install the 15mm spacers? Or were there already indentions behind the stock wheels already.
I wanted to get 15mm spacers but i was worrying about the oem studs sticking out and maybe having to cut a little bit of it off to have the wheels sit flush onto the spacers. Thats why I was wondering if you maybe had to grind down the oem studs a little bit.cjrdriven wrote:Spacers have gaps for old studs. Bolt and play.e464sho wrote:Did you have do any modifying with the oem studs to install the 15mm spacers? Or were there already indentions behind the stock wheels already.
To clarify, you do not have to modify your old studs at all. I should have said wheels and not spacers.e464sho wrote:I wanted to get 15mm spacers but i was worrying about the oem studs sticking out and maybe having to cut a little bit of it off to have the wheels sit flush onto the spacers. Thats why I was wondering if you maybe had to grind down the oem studs a little bit.cjrdriven wrote:
Quad tips was my initial plan...just not 100% on it!! And no not trading in! I'm at peace with myself now and since going from the'07M35 to this'08 M45S Fuully loaded "I realize what it was I really wanted all along.... We have a minivan that gets most of not all the family time so this has become my own personal ride almost 100% of the time... Slowly I will get back to the mods I wanted like the roof spoiler, exhaust and intake!!mexillis wrote:I think quad tip looks best! So I take it you're not trading it in?
