That's an ECU from a 90Q45 base with California emissions (from the complete list given to me by 3Q Jay).Woot! wrote:I just got the part # off of the ECU, here it is: A18 A32 P02.
You need to leave that ECU dangling for a few days and figure out where the loose vac hoses attach. These are definately one of the contributors to the CEL and the EGR code on the ECU.Woot! wrote:I haven't put the ECU back yet, I dont want to put it back until I can get the Check Engine light to stay off.
There are some loose vacuum lines in the engine bay that I don't know where they go. Could that have anything to do with it?
I just checked the title and it says that it is a 1990 I thought it was a 91 when I bought it.goody94q45 wrote:
Will dogoody94q45 wrote: You need to leave that ECU dangling for a few days and figure out where the loose vac hoses attach. These are definately one of the contributors to the CEL and the EGR code on the ECU.
I very rarely drive it for more than 5 min. at a time. After I drove it for a while last night it did end up coming back on .goody94q45 wrote:The EGR doesn't start working until about 20 minutes of driving. This would explain why after you reset the ECU code it (the CEL) didn't come back right away. I'm assuming here that you started with a cold engine. If it's only the EGR throwing a code you may see the CEL go out (and come back on) on longer duration drives.
When they swapped the engine than they couldn't figure out where they went so they just capped them. I think there is 2 of them. What if the new (used) engine is not designed for California emissions than what would you have to do to the new engine to make it work right?goody94q45 wrote:I had a similar issue when I bought my Q (capped off vac hose) and unfortunately there's no pat answer. I ended up reading posts until I understood all the components of the emissions system and then had to troubleshoot each one until I found the plugged hose.
The EGR temp. sensor electrical connection's bracket is screwed to a flat spot on the leg of the plenum that feeds cylinder 8. You should see it right beside the transmission dipstick. I have no idea what the failure rate is for the sensor... I have never heard of one, but it could be bad. The FSM shows how to test it with an ohm meter and pan of boiling water.Woot! wrote:Thanks Heath for the help. The other end to that sensor goes down into the engine somewhere...I will have to dig around and find it.
Do you think it is possible for the sensor to be bad?
Also does the ECU only pull one code at a time or will it give you all the trouble codes at the same time?
I thought the connector end was mounted just about at the #8 plenum intake runner.Woot! wrote:The other end to that sensor goes down into the engine somewhere...I will have to dig around and find it.
The EGR temp sensor is easy to check. Heat a pan of water and measure the resistance with a voltmeter as the water temperature rises. Checking all the components of the EGR system is pretty straightforward and is outlined step-by-step in the FSM. I'm going to guess that you've got a lot of soot on the probe not allowing it to read properly.Woot! wrote:Do you think it is possible for the sensor to be bad?
goody94q45 wrote:The EGR temp sensor is easy to check. Heat a pan of water and measure the resistance with a voltmeter as the water temperature rises. Checking all the components of the EGR system is pretty straightforward and is outlined step-by-step in the FSM. I'm going to guess that you've got a lot of soot on the probe not allowing it to read properly.
You need to figure out where the two capped hoses go before the CEL will permanently go away.
First things first, I've got to find out where the thing plugs into, I doubt there is anything wrong with the sensor other than it is not plugged inWoot! wrote:Update: I just followed the wire from the EGR temp. sensor and found that the end was just dangling down the side of the firewall, but I can't seem to find the end that it plugs in to...
No, it feeds the AAC Valve, left bank O2 sensor, and the EGR Temp Sensor. You should be able to follow it out and find one plug that isn't attached to anything, with an orange and black wire. That the one you plug in to your EGR Temp sensor.Woot! wrote:Thanks for the pics. The ones that you have stuff circled in; isn't that just a plug for one of the injectors?
That's the one coming from the sensor. You're looking for the other wire in that picture... the one that you can barely see the black and orange wire feeding the plug. That's where you'll plug in your EGR temp. sensor connector.Woot! wrote:]The cord that I circled; I think that is the one that goes from the EGR Temp. sensor. Where does it go?
There is actually 2 of them.Q451990 wrote: your mystery tube
That is around the throttle body somewhere.Q451990 wrote:Found this pic... maybe it's your mystery tube, but bent somehow? I would pull the screw out of your plugged hose at idle and make sure it's not squirting coolant (doubtful). Assuming it's a vacuum hose, might as well try plugging it in to your mystery tube.
