One wire is GREEN with a YELLOW stripe and the other is BLACK with a YELLOW stripe.Q451990 wrote:What color wires are coming out of the connector that you circled in yellow in the first pic?
The sensor under the plenum that is cooling related is the ECU temp. sensor, and I thikn the others are your knock sensors.
Heath
So is it possible that the yellow trail is the knock sensors? What will it do if they are not plugged in?
I have had the car started and idling for the last 20 min and it hasn't thrown any codes yet.
