EGR temp sensor with resistor and still have code 35?
xKnownShadowX
Car: 94 Q45a
Engine: KA24E
Problem: Code 35 EGR Temp Sensor
Purpose: Need it gone for smog, CA RULES!!!! :tisk:
I read up on the resistor and got both 100k ohm 1/4 watt and 100k ohm 1/2 watt. My question is did I do it wrong? I cut the part of the plug from the harness and soldered the resister to both wires, in other words parallel. Somebody told me it's supposed to be solder on the other end where the Sensor is close to. What I don't understand is it just on one wire? Or do both wires get soldered with the resistor in between? Or do I just solder the resistor in place between the wires with everything still in place? If it doesn't make sense please let me know and I can draw a picture unless you can provide one that'd be great. Thanks.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
I just unplugged it and shoved the resister into the plug. One end of resister for each wire. Are you getting power to one of the wires?
xKnownShadowX
Car: 94 Q45a
I found the problem, previous owner had cut the wires from all the way down the harness, now I gotta figure out which one it is on the ECU. Never buy a rigged car.
usdms13
Car: 90 niss 240sx
EGT pin is 8 on ECU. ground is daisy chained with coolant temp sensor air temp, and tps, pins 21 and 29. i just had this issue on my car. it was a federal and need to pass calif smog. working on write up for this issue actually.
usdms13
Car: 90 niss 240sx
