Yep its pretty cool, heres the one i got.
http://cgi.ebay.com/ebaymotors...ories
Make sure to call nissan and order part number 32861-H7301 which is the bottom shifter bushing, because the one that comes with it is crap. its only like 3 bucks.
Mine did have ratte, but luckily on the ebay ones that is easy to fix, unlike from what i've read on the B&M ones if you have rattle your stuck with it.
The metal collar on the ebay shifter is where the rattle originates from and if you remove the snap ring ontop of it you can just pull it off and there are two o-rings. I've seen a write up on some thread here where a guy changed the oring sizes or something but i just smeared gasket maker on the part that the collar covers and slid the cover back on and put on the snap ring and voila no more rattle.
