180fan »
https://forums.nicoclub.com/180fan-u3602.html
Tue Aug 02, 2005 9:24 am
If you got the motor out, then you can shoot for the ebay one. The holes won't always line up with those ebay ones. Sometimes, when putting in the bolts, the soft aluminum upper pan will also give out and you'll be shafted with a retapping. Hence why I'd say you can go ebay oil pan if you've got the motor out. If the motor's in, go with the greddy. Better fitment and casting. If the greddy one is out of the budget, get a stock replacement instead of that ebay junk if your motor is already in.
