skydragoness wrote:
Actually I own a Ebay C's-replica shifter, had it for four years. There's one problem with it: the plastic bushing at the bottom of it. It did not fit properly into the shift linkage causing it to wobble around IN GEAR, and if given the proper tug/pull it came out quite easily. Of course I was smart and took the bushing off and used a press to get the bushing from the oem shifter onto the short shifter. Now its perfectly safe and functional, and has several years of autocrossing and spirited driving on it.
To the OP: So yes, somebody could quite possibly get in an accident, hurt themselves, etc if the shifter were to fail. Imagine if you couldn't safely shift into neutral if the shifter popped off?
That $79 unit from Phase2Motortrend is CHEAP. If you can't afford that, then save your money and use the stock shifter. If you think 240sx parts are bad, try finding **** for GC-era Imprezas. Not worth it being cheap... "Buyer Beware"
I was going through some old thread I made, and stumbled across my c's clone review
zerothread?id=155687 pretty much spot on w/everything you said.
On my review, I preferred mine to the b&m clone my brother got, but that is no longer the case. After driving on the b&m clone for a while, it's sweet to have that mechanical clunk. The shifter is great in my opinion, and has seen 3+ years of rough daily driving (my brother shifts like a maniac) and some track days. I really don't understand how ppl are snapping these things (my guess it's that is sintered stock and not billet?). I've got to see a picture of one just to figure it out (i took failure analysis, so a pic may also tell me other things).
It rattles just like the b&m did years ago (don't know if they've fixed it). I do know how to get rid of the rattle altogether, but i've been lazy and haven't modded it (besides, it's my brother's car after all).
PS: the boot that comes w/the b&m shifter is rubber and the grease that's in the shifter eats through it like butter. Getting a oil compatible boot would be an upgrade.
