ceningolmo wrote:That price seems high to me... I think if you are patient you will find that you can pick up a 90-93 Q with similar/less mileage for roughly half your quoted price.
I own two 91 Q45a's and have paid $2000 and $1500 for the two.
Thanks for the compliments. You can see more pics of my car here:bruce.weiland wrote:You have a gorgious car. Exactly the color combo I am looking for and what my 91 was.
Thanks for including the great pictures.
How do you adjust the height sensors?bruce.weiland wrote:I ran it with 255x50x16 Yoko AVS on 16x8, poly sway bar bushing on the chasis, and lowered the car about 1/2 by adjusting the ride height sensors. Drove it from 91 to 97.
Are you saying you didn't ike how the 95 handled or how it drove with the big 17" tire combo you were running?bruce.weiland wrote:
I loved the way it handled. The 95 had 255x45x17 front and 275x40x17 rear. I did not like it nearly as well. I also missed that great front seat that was in the 91.
Pretty much have to go 17" (short term) or 18". On the best tires, the ride is still pretty darn good.bruce.weiland wrote:What are guys and gals running now that give great handling without screwing up the ride.
Go to the top link on this Forum called "OFFICIAL G50 (90-96 Q45) OWNERS CHECK IN!" and my car is on page 5.bruce.weiland wrote:Lino,
1 Your welcome. I could not get that page with pictures to come up.
Did the lowering of the car make a noticeable difference in feeling or just appearance?bruce.weiland wrote:Lino,
2 Ahhh, now that is a secret. If I tell you I will have to kill you.
No, actually it is quit simple. I haven't done it in a long time. As I recall the front sensors are very easy to do. You need a phillips screw driver, as I recall. Look in your manual for the location, they are each out close to the control arms.
The rears are a little more difficult to get to, but not bad. You need two small wrenches, one for the locking nut and one to adjust it. I think they were 8 and 9 mm.
Measure you wheel arch height, car running, on a level surface. Pull the car up on ramps and adjust the front. The back the rear up on ramps and adjust the rear.
Drive the car around the block then put back on the level and see were your wheel arches are. At that point it will tell you how far you have to go.
It really is quit easy and does not take too long. Once your good at it, less than 30 minutes.
I'm running Bridgestone Blizzak 215 65 Q15 winter tires since I bought the car. I put them on it a year ago, and still haven't changed them. I don't know what an 1991 Q45a feels like with real tires yet . I'm planning on buying new wheels and tires this spring.bruce.weiland wrote:Lino,
3 And YES, I did not like the way the 95 road. Handling was OK, but did not seem as responsive or comunicative as the 91. I don't know why 1/2 inch less side wall would make that much difference, but it seemed to. I had them mounted on 8.5x17 front and 9.5x17 rear. There were some differences in the 95 active as far as softer bushings and some program change. That may have been part of the problem.
I did a quick search for 255x50x16 tires at discount tires direct and did not come up with much.
I am in dry So. CA. so max. performance is fine.
Thanks
Bruce
Start with the tire sticky in Infiniti General.bruce.weiland wrote:I am going to look to the wisdom of the group. I haven't researched tires for several years, so I don't really know what is good out there.
Performance tires have disappeared in 15" and 16" diameters with applications for the G50. They will be gone in 17" soon also.bruce.weiland wrote:I haven't looked at tires for a while. Do you say 17" short term, because there are less and less 17" tires available? Or was there a different reason?
Any size and brand recomendations?
A few people are. But read Q45tech's posts about tires and dynamic handling. Little reason to add more rear grip which increases understeer. Now with different spring rates (springs, tires, and anti-sway bar).......bruce.weiland wrote:Is anyone that you know of running staggered front and rears, like 275 or 285 in the rear?
The Goodyear are good, the Advan areprobably not strong enough.bruce.weiland wrote:Either Yoko Adavan or Goodyear F1 on 18x9.
OK, I got the tires all I need is the car. Kind of like the beatles song "Drive my car"... I've got a driver and that's a start.
Just realize that once you go to 18", the expense increases dramatically.bruce.weiland wrote:Haven't found Q45tech's handling dynamics post yet, but....
I did see your on wheel size and tires used.
Although I can adopt affectations at times, I am thinking 255x40x18
Thanks Brian
1.) But so does the performance in the top tier. Many of the top tier tires are no longer available in 17" sizes that will work on the Q45. It's like you get for which you pay, or you take your chances. Since tires are the only interface between the car and the road, false economy here can cost you dearly on the street. Stopping 12' shorter and not be in someone's trunk or holding a curve at speed in the rain can be priceless.DrewQ45 wrote:
1.) Just realize that once you go to 18", the expense increases dramatically.
2.) Just about all 18" tires are high performance directional tires which cannot be rotated side to side without flipping them on the rim. That would garner the same cost as mounting them all over again.
3.). Now some people like directional tires because of the linear tracking feel they provide while on the highway or at high speeds. I personally like that feel at speed but dislike it at low speeds. On my Q, the steering had a tendency to fight to return to dead-center which I found annoying when tooling around. If you can go with 17" I'd suggest it based on $avings and less hassle.
..Drew...
Agreed with almost all of what you said. As you know I personally opted for 18" but not everyone is as willing to pay to play so I'm pointing out the drawbacks.maxnix wrote:
2.) Personally, I flip mine every 5K anyway to extend life. .
3.) Neither do I have to fight to return to center, but only the FY33 has non stock springs (Eibachs).
While 17" is certainly cheaper, the perforamnce frontier has moved on, and the future for 17" looks no better than 15" and 16" did a couple of years ago. I wish it weren't so, but it is.
