Eagle rods/300zx rods
ADAMHU
these are the ones...
manley big block pro series I beam rods
900hp rated at 8000rpmsee bottom of link
http://www.campbellenterprises...s.htm
better_than_sx
Car: 1989 240sx
beefy
andrave
Car: 1989 Nissan 240SX Coupe
damn wonder what modifications it took?
yashin
Car: football, rugby
I'm assuming the cost of having custom pistons fabricated probably destroyed any possible cost savings. Dammit I may have to just by pauter rods. Any body know of any other type that's also good?
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
Ah, "nascar" rods. Those are basically one-offs (nascar likes to play with different crankshaft journals). That is the way the "honda" journal sbc rods came about. ADAMHU, most likely the be width has been resized, because you are using chevy bearings correct? Normal off the shelf cheap bbc rods will not work like that for anyone tempted to buy a set of 8 for 200 bucks, these have a custom 2.00" or smaller journal diameter. Btw. im working hard to make affordable high quality connecting rods available for the ka's.
WDRacing
ME too....but its an up hill battle.
andrave
what if you just cut the crank of the ka journals down to that size???
deviousKA
ka crank rod journal is ~1.960-1.970
sbc chevy, small journal 2.00sbc chevy, large journal 2.10+sbc chevy, "honda" 1.88 (.940" and narrower widths)bbc chevy, standard 2.3+ (available in lenths to suit ka)
the bbc rods are larger journal diameter, so you could not grind the crank to size. Sbc could be done, if you found an appropriate length, and uncommon width (combined with undersize rod bearing). So the "uncommon" width is basically an unfinished rod
andrave
eyesea.interesting. useless to me at this point in time. But interesting.
ADAMHU
i had the custom pistons made so that i could run a flat top piston which is very good for racing, and have huge ring lands made so that i can boost the heck out them, i also had if you look very long skirts made to help dissipate the heat since the ka24e does not have oil squirters like the DE
adam
yashin wrote:I'm assuming the cost of having custom pistons fabricated probably destroyed any possible cost savings. Dammit I may have to just by pauter rods. Any body know of any other type that's also good?
yashin
I'm not looking for anything too serious as far as power goes. i'd just like a little security. Just in case. And paying 1300 cdn for rods would put me over my budget.
Maybe just get the stock rods shotpeened?
