When I got this turbo there was no info on it, but BW has recently released the info on it....Cjmartz2k wrote:What's the exducer size on that turbo? I'm running a holset with a 60mm inducer and 84mm exducer. The BW's are supposed to spool a little better with like 1 more pound/minute, but all in all, pretty similar for equal sizes. What did you make on the 42R?
Time to turn that bad boy up to 1.8 bar and see what it'll do
*Edit--is this the extended tip?
Stock block, Tomei HG and ARP headstuds, stock head, Tomei Type A cams....jdmser wrote:Are you still running the stock short block? Any head work? Bout how long did the tune take?
Its most likely the engine actually being louder than the turbo. You would not believe how loud these open wastegate dumps sound at 8400 rpms......def ear piercing!KUILLIN_DRIFTER wrote:i don't know if it's just me or my hearing but when full boost hit the turbo WHINE seemed to fade and it was all motor after that. First time i've ever experienced it. Ever suck in babies with that thing?
That is a myth......E85 is not corrosiveSil240 wrote:There probably was a thread on the E85.But what did you have to change to run on E85?Just Fuel lines and Tuning?I heard that E85 was very corrosive.
It was no fun with the auto, and it really took away from it being a 'street' car.......I've been back on the 5spd for a few months now, and loving it!Darius wrote:Do you still have the auto transmission on there?
Ironically, no changes were made mechanically. I already have 2 300ZX TT fuel pumps....and 1000cc injectors. My injectors were about 80% duty cycle on the dyno runs I was making.....still have a little room left out on the tableDarius wrote:Larger injectors and fuel pump than you'd normally size. What AFRs (lambda) are you tuning to since it isn't gasoline?
Bah. I'm 2.5 hrs away from you and E85 is $3.30/gal and Regular 87 / 89 octane is $3.59. There is only one local chain that carries E85 (5-6 stores).Booztd 3 wrote:Once I get back to the dyno with my boost controller issue fixed (which it is now) I should be able to make around 600rwhp if the turbo is up to it......
That and E85 is available at the pump, and 2.80 a gallon....
The curves with the marking "2" on them are at wastegate pressure 19psikrayton wrote:Booztd 3, you have your dyno graphs?
Just curious on your power and torque curves
"74mm garrett" and "good response" dont belong in the same sentance....krayton wrote:very cool. do you have the graph with your old setup running the 74mm garret?
trying to get an idea of a 600+ turbo with good response.
Sitting at 20 right now, might go to 18 or so when we shoot for higher boostHxC_Nismo wrote:what spark plug gap do you run with e85??? cause i have been thinking of converting
I'm pretty confident this turbo will reach 600 with a good hotside on it. It will take some tinkering on my part, but I believe I'll get it.
The turbo started losing its boost around 6300rpm or so......notice thats where the HP curve basically stays flat......if I'd have been able to sustain 27psi or so, i believe it would have gotten to 600rwhp
