virus77 wrote: ill leave him a $400 deposit untill i return it to him with paypal.
if it was mine i would. i basically did the same thing. the techtom is ryans (klattr1). i gave him a deposit and he let me borrow it. its going back to him next week. i bought an apexi multichecker. jsut need to figure out the wiring.
hey WD if you tell me how to wire in the resistor ill do it.
daneil- you're not quite grasping the timing issue. whne we talk about having 17 degrees TOTAL timing. this mean when we are at WOT boosting. only way to check that with a timing light is on a dyno while somone is boost the car at wot. or to have a monitoring device. with the car idling and tps unplugged, you are checking the base timing.
base timing for kade - 20 degrees at 700rpms with tps unpluggedtotal timing for kade - 28 degrees at wot under highest load
so if someone retards their base timing with the distributor 4 degrees. this would give them:
base timing of 16 degreestotal timing at wot of 24 degrees
with something like the btm or other tuning device the base timing would remain the same but total timing would get retarded.
