Dyno Sheets
Two-Fortee
Car: 180sx.
Any idea what I would likely hit with thes mods?
Internally stock caGarrett GT28r turbo off an s14Front Mount IntercoolerGreddy RS BOVK&N Intake3" turbo back exhuast with testpipeWalbro 255 Fuel PumpHKS EVC IV Boost Controller
I'm figuring about 210whp on stock boost....
Noz
Car: 1991 200SX S13
Stock CA18DET engine, well almost! Just running 2 x standard headgasket:
382.8bhp & 326.2lbft @ HUBS or285.45kW & 441.77Nm @ HUBS
1.7 bar on an SSA T70 (=Garrett T61 copy I believe)
Is this the highest power non-forged CA? Please let me know cos I've got more boost to spare
Modified by Noz at 6:12 PM 2/28/2008
chausaster
Car: 1990 Nissan 240SX Fastback CA18DET
Well here's my dyno chart from a 2 years ago when I was learning how to use megasquirt. I was running 15 psi on a t28 turbo, megasquirt I v2.2 fuel only, stock ignition, 2.5" exhaust, 460cc injectors, FMIC, yada yada
Hillkill
Car: s12(killed), s13 hatch(rebuilding CA), s13 coupe(low & slow), e30 4door, FJZ80, ThunderChicken
s14 t-28~1.1bar550 injectorsz32 Maf FMICChipped Ecu Safc2Hks Pod Filter Greddy Type S BOVCircuit Sports Dump/DownpipeStupid Manual boost controllerCoated and heat wrapped tubular exhaust manifoldOs Giken twin plate and flywheelCopper plugs for a honda???Ka throttle body and bored intake manifoldAll IAC stuff is goneReused Greddy headgasket and Arp head studs Stock Head and internalsAnd the Best Part is it's in a S12
Giallo spyder met
Car: Nissan 200sx -92 Euromodel
More to come...Had a break down.On regular fuel.
21FOX21
Giallo spyder met
New Swedish record.And now its mine..
Its 514hp at the hubs and 330hp/L and no racefuel or nos.
n13scb
Ca18det:
Top mount t34 turboStainless systemApexi filteromex 500 ECUGtr injectorsRx7 fmic
magnus in aus
Car: 89 nissan silvia
I made 204 kw @ 16 psimakes full boost at 16psi at 3800rpm and peak power at 6500
I have a boost leak atm, so it goes to 20 psi and leaks back to 16psi.will sort it out and go back and tune for 20 psi
Ca18detforged bottom endrebuilt headHKS 264* with 8.8mm lift in and outTrust Td05 16g with external gate low mountGtr injectorsmicrotech ecuwalbro lift pump & 044 feed pumpstraight pipesfmic
heres a bad video, doses like a VLhttp://au.youtube.com/watch?v=C-PVvtb4XGA
[img]http://g.imageshack.us/img296/dsc00098ej9.jpg/1/[img]
jrsink
here's mine.223 WHPca18det with t28 pulsar turbo running with megasquirt and ford escort EDIS ignition, FRONT MOUNT,FULL EXHAUST. thaTS IT!WHAT DO U THINK?TUNED BY MARTIN AT ZFEVER IN TAMPA.
le fou suisse
Car: Nissan 240sx s13 swap ca18det
hello everybody :-)
this is my old dyno sheet :-)
389ps471nm
next evolution is gt3071r :Dca18det with gt2871r running at 21 psi unstable
Wannab
Car: S13 hatch Drift car
Good numbers..........I had no idea.I still rock a KA
mydato
Car: Datsun 1969 1600 / 510
Datsun 1967 1000 Wagon VB10
This is my dyno chart.
Datsun 1600CA18DETCA16de camsGT2560 turboZ32 MAFGTIR injectorsForged bottom endStock headInlet butterflies removedFront Mount IntercoolerTurbosmart Boost Tee bleed valve
Modified by mydato at 10:59 PM 7/5/2009
Giallo spyder met
progman
ca18det
gt28r
megasquirt2 v3 firmware 2.89
262rwhp on a mustang dyno.
Anu
Car: Nissan 200SX s13
Mods:
- Stock CA18det
- Apex'i open air filter
- Walbro fuelpump
- 3" Exhaust
- Apex performance engine mounts
- Garret GT2554R turbo
- DBpower 56mm radiator
- Front mount intercooler
- 444CC injectors
- S14 MAF
- Nistune mapped by Steve from FCtuning
This is my sheet:
277,8 hp / 363.5 nm torque
Power @ the hubs is 241.5 hp
nickmerrone
Car: s13 hatch
188whp..so idk how much to the crank.
Mustang dyno so it reads a bit low
8 psi
SR t25
300zx filter
walboro 255 fuel pump
Greddy FMIC
Apexi intake
No BOV
full exhaust manifold back.
21FOX21
425HP 386TQ Mustang Dyno
25PSI T3/T4 57trim
float_6969
Good looking numbers there fox. Is this on pump gas? were you fighting detonation? It looks to me like you could lean it out a little and gain some more power in the top end and run it out a little further on the revs and gain a lot of width in that power band.
beans33
Car: 1993 ca18det 240sx
Agreed. I would like to know more about it also.
Tanel
Car: Nissan 200SX
Hi everybody, greetings from Estonia!
Nissan S13, CA18DET, Holset HX40.
692hp and 789Nm from engine.
Did 293kmh on a standing mile.
1/4 mile with no traction 12.0 @ 214kmh 2.45@60ft
2009 had 560hp from engine and did 1/4 mile 11.7@191kmh 1.66@60ft on ET Drag slicks.
Tanel
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
My CA hasnt run in a while and Idk where my sheet is but here was my power and mods.
(I think all this is correct, It's been 2 years since I dyno'd)
244whp/227wtq on Dynojet @ 14psi 93 octane
Stock CA18DET
SR T25
AEM Dry Flow filter
3" muffler shop exhaust (crush bent) with stock O2 housing
Godspeed fmic
Turbo XS RFL BOV
Stock injectors @ 4bar
N60 maf
SAFC (for maf cal and trim a little fuel down low)
HKS EVC 6 boost controller
HKS Type 0 timer
ACT Extreme 6 puck on stock flywheel
J30 3.9 VLSD
17* base timing
I didnt have a wideband in my car at the time but IIRC the wideband they used on the dyno was somewhere around low 11's but dont hold me to that. I'll find my sheet one day and I'll edit this post by uploading it
srt4monster
The boost is about 2.5psi lower then what the graph shows. the higher boost pull had spark blow out.
stock motor with head studs.
n60maf
560cc injectors
62mm turbo
full 3" exhaust.
mdb4879
Car: 1987 Nissan Pulsar SE (CA18DET)
1990 Nissan 240SX (KA24E)
1995 Acura Integra GSR
Just got mine dyno'd today:
147whp 160wtq
Mods:
None to note
1 worn out CA18DET
Small ebay FMIC
"stock" wastegate pressure on stock T25 (somewhere between 10 and 12 I think with a spike as high as 14 on a worn out wastegate actuator and 3" long exhaust after stock turbo elbow)
I say 10-12psi because my gauge reads about 10 when everything is settled out, but when the car is off the needle sits about 2psi below 0.
@3800rpm - BUTTERFLIES JUST KICKED IN YO!!!
float_6969
I think your gauge is fubared. Pressure on stock T25 is about 7psi. Maybe if the diaphragm is a bit leaky, it'd run a bit more I guess. Regardless, it looks like it's pretty consistent and runs well. Most importantly, do you enjoy it?
mdb4879
Oh yeah, definitely. I wouldn't care if it dyno'd at 80whp, because I still spin 2nd just from power. A dyno is just for point of reference, so as long as the dyno is consistent and will show what changes I make do to its performance I'll be happy.
I have some cheap GlowShift gauges, so it wouldn't surprise me if they were off. I had heard with a free-flowing exhaust the stock wastegate will make 10psi, so I figured if I had a worn out actuator on top of that it'd be close to twelve. It performs slightly different every day, and every once in a blue moon I'll hit boost cut.
s13drifter88
I dont trust Arthurs dyno too much cause his is what said my stock CA with SR T25 at 14psi made 240whp. Idk, I was happy when I saw that but the more I think about it that cant be right, thats high for a T25 CA
mdb4879
Well like I said, as long as it'll perform consistently I'll be happy.
I may be wrong here, but from what I've gathered from other people's number I have a theory about how much a CA will make given certain mods. I think the stock cams will make max power at close to 7200rpm. If that is the case then here's what I think:
Stock power = 175hp @ 6400rpm and 7psi boost (21.7MAP)
175/6400*7200=196.875
196.875/21.7*28.7=260.38306
Idk how much drivetrain loss there really is, so Arthur's dyno may be a bit high, but you may have been able to 260hp at the crank on 14psi if the turbo wasn't choking up there. Especially considering your lager than stock exhaust and FMIC.
Even if the cams will only breath up to 6800rpm, that's still (theoretically) 246hp. Yes, the factory spec is for a new motor, and all of ours are worn out a bit when we get them, but we also usually have some minor upgrades that may make up the difference. At least this is all my speculation anyways.
bimeur
Car: rs13 '94/ca18det
My set-up :
forged pistons
forged rods
OEM crank
HKS Stage1 camshafts
OEM injectors (370cc)
OEM MAF
Stage1 (or something like that) chip
some LW pulleys
here's the dyno :
there's an instability with my BC, I don't know why, but I'll resolve it.
Luchitosan
Car: Nissan 200sx Ca18det 4 port
How much power eats the transmission ??? anyone knows ?
