Dyno Sheets
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
Hey guys, just a thought, i think we should have a sticky of dyno runs with CA's.. just so we know how all are going and things.. so, post up your sheet, and give a few details
I'll start.. stock CA, stock ca turbo, gtr injectors, frontmount, walbro fuel pump, safc, full 3 inch and hks dump pipe and a really dodgy boost controller as you can see
So guys, please, post your sheets up !!
Pete.
boost_boy
Mods include:
1 internally stock CA18DET
SDS EM-3F engine management system
4 MSD 72lb/hr injectors
Walbro 255lph fuel pump
Custom turbo manifold
T3/T04E stage III turbo .60 A/R and .48 exhaust housing
Custom bar and plate intercooler
Greddy Type R BOV
Blitz dual SBC boost controller and turbo timer
Oil, boost and A/F gauges
Custom axles
Complete NX2000 brake system
Nissan Maxima brake booster
Custom gear box
This run was done in January of this year.
This run was done on the same day, with the same mods, but with 20 pounds of steady boost.
This run was in January of 2004 and done with the same mods above except for the fact that the turbo was smoking, a different turbo manifold, 2 bovs, the car was run a bit hot along with the intake temps being a bit too high for me, and a set HKS 264 cams with 8.5mm lift, and boost was set at or around 13-14psi. I'll post more when I get a chance.
Dee
tineira
this is mine. 100% stock everything , base map.NON JAP spec engine (Chile)
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
mods so farstock injectorsKa24e MafCp pistons264 cams tomei valve springslog manifoldEvo III big16G custom open dump 2.5" 02housing 1.5" dump tube. 3" exhaust no cat or test pipe.walbro 255 not hardwired (will be doin so ASAP)
this computer is acting up so ill post the videos and dyno sheets later...
but give me some of your guess's of what i made power wise!!! blitz SDC-id boost controller (not hooked up correctly tonight ) so i couldnt dial in boost like i wanted too... 13.6psi, and a 14.1psi run, i also have a nasty leak between the manifold and head so i think im loosing some spool up time .
Spectre23
Car: S13 CA, 2013 STi, Tony Kart
Well, I posted mine on a thread a few months ago, but now that there is a sticky, I will repost it.
Base run on this chart is 11 psi aka "Low Boost". The Test run is at 15 psi aka "High Boost".
Mods include: 440cc injectors, Nismo FPR, 3" Megan Racing turbo-back exhaust, ARC side mount intercooler, GT28R turbo, Walbro 255 lph fuel pump, Greddy Profec B spec II, custom tune ECU (yaaay romulator), crappy spark plugs for tuning, Q45 MAF (stick to Z32 if you are smart), oh yeah, an AFE cone filter too. The engine internals top and bottom are completely stock.
boost_boy
SLIPIN wrote:hey people im all the way from NEW ZEALAND and just found your web site i own a s13 200sx with a CA18DET in it. its great to have a forum all about CA's heres a couple of pics of my car and my CA_POWER!!!!!!! motor
and my dyno
SLIPIN wrote:hi thanks for the warm welcome hahaha the spec of my motor well her it goes
Custom made turbo rated up to 600hp same size as a T66Port and polished (flow bench tested) head done buy leading edge cylinder heads Heavy duty valve springs and new valves in the headCam’s inlet 278’ Exhaust HKS 256’Tomei adjustable cam gears IN/EX Ross forged pistons Shot penned rods A polished and balanced crank and all new race bearings 500hp walbro fuel pump 710cc injectorsmallipassi fuel pressure regulatorZ32 airflow meter Trust type R blow off valve All aluminum custom intercooler pipingCustom FMICCustom top mount headers Custom 1.5mm steel head gasketCustom made 5 puk heavy duty clutch made buy exedy race clutches in OZ Custom made steel lightened flywheel Custom made 3 inch dump pipe straight off turboCustom made 3 inch exhaust all the way through 38mm delta gate mark 2 wastegate60mm Enlarged throttle body Apex’i AVC-R electronic boost controller Apex’I AP Engineered CA18DET Power FC Samco sport blue intercooler joiners and 3 inch into 4inch turbo joinerRadiator has been cleaned and new top hats put on New water pumpNew battery All new beltsBrand new DBA slotted and cross drilled brakes Brand new up graded brake pads Adjustable coilover shocks - hot bits (this is the brand name there not stolen) 17in x 7.5in TE37 Replicas with 215’s on them This is all I can remember of the top of my head but I know I’ve missed a few things
the tune that its in at the moment is only a half tune it was tuned on 96octane pump gas and it had only 10km "6miles" on the motor when we put it on the dyno so we only took it up to 7000rpm and 18psi when i take her back im hopeing for 300rwkw @ 8500rpm and 25-26psi of boost
nismoplsr
Mods:~GT28RS (Disco Potato)~Lucas 550cc injectors~NISMO adjustable fuel pressure regulator~Z32 TT fuel pump~TurboXS Type-H BOV~Unorthodox lightweight underdrive crank pulley~Spearco 26x6x3 interooler~2.5" intercooler piping~2.5" exhaust~Haltech E6K~Greddy TT~Greddy Profec-B specII
Kicky-Fast
Car: RPS13
Well my friend told me to post...had my Ca for over a year and on my 2nd 240 in 3 years LOL so heres what i put down...with following mods :
Stock TurboStock ECUStock InjectorsStock single cam fuel filterPlugs gapped to 35Custom DP 2.5"- 3"Custom 3"inch exhaustHi-Flow CatFMIC with 2.25" pipingHDR ( home depot racing ) boost controller at 1.0bar spikes at 1.2bar92 octane pump gasWalbro Supra TT fuel pump
capwred
i got my ca running ok after all the trouble i have been having with it in the last week.still not running just right.but i had a ok dyno run.i put down 159 at 10psi and 189.5 at 13.5 psi.the air/ fuel was 12 straight across.i think it will hit 200 after getting it running better.i was running old plugs and that was on 93 octane pump gas.maybe next month i will get to go back and do some more dyno runs before i get the new turbo.i will get the sheet on here later
mods on the carsr t25 blitz boost controllergreedy 3inch down pipe3inch high flow cat3inch trust cat backelec. fansafc2
silvia_ca18det
Car: 350whp ca18det drift silvia
here is my dyno sheet from spring time, i have recently dissasembled motor to make way for 400+hp here is a dyno sheet done in japan!
Modified by silvia_ca18det at 10:15 PM 12/8/2005
Bugatti
Car: 200SX -92
Mods:
-Accralite forged pistons 0,50oversized-Sten Parner motors h-profile steelrods(4340)-Jun intake/exhaust cam 264/9,3mm-Adjustable cam gears-Gt3076r-wg-1,2mm Trust headgasket-Stainless steel manifold-550cc Denso injectors-Front mounted intercooler-Megan racing fuel pressure regulator-3" system from turbo-Rpc-x Stage 2 Cluth-Apexí avc-r-PLX m-250 + 52mm gauge
257hp@6500rpm 0,79bar/11,45psi More to come
Modified by Bugatti at 4:14 AM 5/24/2006
JDMSIL80
Here's my mod list:
Bone stock motorGarrett GT28R444cc GT-R injectorsHorsham stage 3 chip or Apexi Power FCBlitz I-D color EBCFET coil packXS Power FMICXS Power turbo manifoldXS Power down pipeMegan Racing exhaustHKS SSQV recirculatedHKS Power filterZ32 MAFWalboro 255 fuel pump
The first run I pulled with 11psi netted me with 222whp & 176wtq
Then we did a couple more runs by increasing the boost level. And finally, I made with 289.7whp @ 6500, 258wtq @ 5800 @ 18 psi
Modified by JDMSIL80 at 7:25 AM 7/18/2006
mikesim
Before: cat back exhaust, stock boost, 80F day. After: GT2530 turbo, 3" turbo back, DSM injectors, walbro 255, s-afc 2, greddy 10x10x4 FMIC (stock pipes), greddy vvc, and WG actuator had no pre-load, so boost came in really late. 88 F day. AFR's 10.5:1 in full boost. ecu was enriching the afr's to compensate for high IATs due to hot and humid day.
I'm taking it back after figuring out the boost problem the other day.
rexhunta
MY10 Forester X LE
225.8rwhp.
t25g, emanage blue, 444 injectors, rb20 afm, stainless mani, full 3 inch, fmic. 1 bar.
f s t caz
Car: VG30ET D21 Extended Cab Pickup
GTiR T28SSAuto equal length manifoldssauto elbowfull 3" exhaust - no cathallman boost controller - ~13psiZ maf450cc injectorstuned on s-afc
OverBoosted180
Car: 89 S13 CA18
Here's the results from last week's dyno session that Dee and I did. The car was tuned pretty much to perfection with the car revving out at 6800 rpms due to a malfunction with the MSD and the SDS's limiter.. Imagine 8000+ RPM's.....Stay Tuned..This was the car's first dyno session EVER!
Dyno Session Pt. 2 Coming Soon..........
float_6969
197RWHP @ 15psi
CA18DETstock camsport and polishSSAC maniCA T25 3" turbo back exhaustForged aluminum pistonsbored .020"10:1 compressionbalanced bottom endlightweight flywheelSDS EM4-F
There are no torque curves on this chart. This is a comparion of the CA's T25 at 10 psi vs about 15psi
NeedCAforS13
Car: CA swapped S13 coupe
finally got to a dyno with my new turbo. 268whp at 15psi.
internally stock motor, stock cams, stock headgasketstock exhaust manifold and o2 housings14 bb turbo (gt28r)dsm turbo injectors (460cc)maxima n60 mafr33 gtr intercooler3 inch downpipe, 3.25 inch exhausthorsham developments stage 2 rom tunesafc2or injector and maf correctionhallman manual boost controller
car feels really good this was a 4th gear pull by the way.
1SlowCA18DET
t3t04e 60 trim @16 PSIUsing rom editor and a pocket romulatorz32 maf750cc injectorssard fuel pressure regulatorz32tt fuel pumpcp pistons
sideways danny
Car: s13, CA18DET
wiseco forged pistons,lightened balanced bottom endstd flywheel lightened 4.5kgre-worked cylinder head, quench removed, extensive porting (4 port head) 1.3mm ACL MLS head gasketCA18DE inlet camport matched inlet manifoldKA24 Throttle body, plenum opening enlarged mild steel tubular exhaust manifold, GT2860RS 0.86a/r @0.9barstandard O2 housing2.5 inch scorpion exhaust (twin exit)large FMIC painted matt blackRPS Max Street clutch370cc injectorss13 ca18det standard AFM
Modified by sideways danny at 7:06 PM 1/3/2007
Car: 1992 240sx coupe
235whp, 211ft/lbs @ 10psi
299whp, 247ft/lbs @ 15psi
EDIT: MODS
Stock ca18detPorted Intake TB Openingstanza Ka24e Throttle BodyGM Coil packs, Waste Spark Ignition, Custom Dwell Map in ECU3" O2 Pipe, Full 3" Exhaust with TestpipePrecision GT3071R dual BB TurboStock airbox with K&N highflow filterSocketed ECU with custom tuneFMIC 31x4x6Custom Oil Catch CanPS & AC Belts removedN60 MAFSNismo FPR @ 55psi
Modified by 50-50 at 2:10 PM 5/15/2007
Nunook
I just got back from the dyno alittle while ago, and it was pretty good. In my stupidity, I forgot about my cam gears and couldve tuned for alittle more.
This is:+++stock ca18det w/s14 nonBB t28 w/ hks adj. wastegate actuator10lbs of boostlightweight flywheelebay aluminum pulleys, NO A/Caltima fansJohnnyRaceCar Intercooler 2.25 hot side, 2.5 cold side pipingSelf Tuned ECUs14sr AFM w/ K&N cone filter.3" Dump, DP, exhauststock injectors Sard FPR raised to 42psi- - -stock throttle body, stock exhaust manifoldabout 145cylinder compression and metal shavings in oil
Nunook
These were when I just got my engine installed and broken in.The first is stock boost, stock KAE fuelpump, T25g, crimp bend steel intercooler pipes with no BOV. on a 7mgte stock intercooler YES clutch fan, A/C, 3" downpipe and exhaust. Air filter.
The 5th run is same setup, same day but 12lbs of boost, Home depot MBC.
I love MBC.
jrtuning_ben
Car: s13 200sx
Car1989. 200SX RS13; CA18DET
Power-related modsk&n air filterapex group buy fmicxspower manifold and elbow3 inch exhaust systemca16 inlet camka24 60mm tb440cc injectors.86 gt28rswiesco +1mm forged pistons1.6mm metal head gasketrb20 afmocho mapwalbro fuel pumpz32 fuel filter
Boost1.3 bar on avcr but averaged at 1.2 on rr
RR Results363.3bhp @flywheel330 lbs/ft
all with a dodgy overfuelling issue
BigTone
Car: guess!!!
heres mine...
sydwayz
Car: 1992 nissan 240sx
over 600 hp is baller but that has to be on an engine dyno
Rookieca18det
Car: 93 hatchback (ca18det)
I dont know man ND builds some sick cars...not sure if that is who built the car.
float_6969
ca18silvia_n.a
Car: s13 silvia
Hi guys, this is my first post on this forum so please let me introduce myself real quick, my names Daniel and I drive an s13 Silvia. I live in Sydney, Australia.
My car has a 100% stock CA18DE engine. Because of new laws here in NSW I cant drive a turbo/supercharged car until I have my full license which is another 3 years away. So my aim is to build up a non turbo CA that everyone will admire. The cars first dyno run was very dissapointing even for a stock non turbo, but this gives a lot of room for improvement as long as the engine isn't completely stuffed
Here are my dyno results:
sideways danny
Car: s13, CA18DET
same mods as before but with adition of RB20 AFM, 460cc injectors (RX7) Tomei 256/8.5 cams and some more boost
